2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
What’s these 2022 Superduty in trough by windshield wiper
Old 11-07-2023, 10:57 AM
Readgriff's Avatar
Readgriff
Readgriff is offline
These were found where wiper motor shaft goes thru the trim outside by windshield. They look to be some kinda key they a metal.
Old 11-07-2023, 11:11 AM
number9xd's Avatar
number9xd
number9xd is offline
Keep those. You need to JB Weld / epoxy them back into the wiper arms so they don’t fall back out, which will result in the wiper arm getting stripped out and not working.
Theres threads on here about it, known issue.
Old 11-07-2023, 11:12 AM
4wd6.7L's Avatar
4wd6.7L
4wd6.7L is online now
Received 2,098 Likes on 1,577 Posts
They are the wiper arm keys. They locate the wiper arms in a specific position. Some glue them back into the wiper arm in hopes of strengthening the connection. Ford in the past has called them out as being for assembly purposes only, and not necessary, but some owners in locations with heavy snow may have experienced slipping of the wiper arm. The wiper arm recall that had to do with improper spline height, also had some owners more paranoid about keeping the keys in. The recall included a step that adds glue on top of the keys but it was only an interim procedure until new parts were available.
Mine have been out for 4 years, no problem yet....but also no snow haha.
Old 11-07-2023, 11:22 AM
number9xd's Avatar
number9xd
Here’s a link
https://www.ford-trucks.com/forums/1...er-arms-4.html
and another with more pics
https://www.fordtremor.com/threads/w...ed.7835/page-2
I JB Welded the keys back in my wiper arms and let them cure overnight before reinstalling. LAST thing you want is for the epoxy to permanently bond the wiper arm to the truck. Just make sure the epoxy doesn’t get in the splines of the wiper arms. Just a light skim on the key is all that’s needed.
Old 11-07-2023, 11:37 AM
Rwhjr's Avatar
Rwhjr
Rwhjr is offline
My 21 truck had issues during snow.
I wasn’t aware of the issue and was confused at first. Turned wipers on and they wouldn’t move but I could hear them trying to operate.
took 15 minutes of messing around to finally pull the wipers off and I saw the little wheel they side over that turns them.
after finagling them and reattaching they’ve worked ever since. I’m sure my little tabs tou pictures fell out but I haven’t had an issue since that day either, so….
Old 11-07-2023, 12:11 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,396 Likes on 1,798 Posts
There is a recall out for that.
I had the recall done, even though the keys had been glued back in the wiper shafts months before.
Old 11-07-2023, 12:15 PM
BC2019F250's Avatar
BC2019F250
BC2019F250 is offline
My truck has been through 5 winters and no issues with them not being in place. Anyone that lives with snow should know better then to clear the windshield of snow with the wipers! That is what they make snow brushes for.
The following users liked this post:
Old 11-07-2023, 12:35 PM
4wd6.7L's Avatar
4wd6.7L
That seems to be a misconception. True, there is a wiper arm recall and the OP's truck might be included in it, but the recall actually is not about the keys. The cause for the recall was out of spec splines in the wiper arms due to some worn out tooling used in the manufacturing process. The recall pass or fail is determined by a date code in the wiper arm. The presence of, or lack of the keys is not a determining factor.
This same type of wiper arm has been used for many years by Ford, and the keys have been known to fall.out for just as many years.
The following 2 users liked this post by 4wd6.7L:
Old 11-09-2023, 05:40 PM
scottz99's Avatar
scottz99
scottz99 is offline
Thanks for the heads up. I checked and found this on the left side. I pulled both wiper arms off; the key on the right side is also gone; totally gone, guess it did not make it through the car wash. I'll glue the left side on; should I worry about the right side? Can I get a key from Ford? PS: I know it is not related, but no wiper recall on this truck; build date Feb 22.
Old 11-10-2023, 09:16 AM
Readgriff's Avatar
Readgriff
I went with the keys to Dealership they put new wiper arms on. Thanks for the replies.
Old 11-10-2023, 06:34 PM
Antoniodef's Avatar
Antoniodef
Antoniodef is offline
I worked at world’s biggest auto glass company for awhile. They are keys to align wipers. They fall out, we usually didn’t bother putting them back. We were told same thing, they were for assembly. Some people actually wanted their wipers adjusted out of the factory spec (wipe higher or lower on windshield), and you had to take them out for that.
saucemann
2017+ Super Duty
12-24-2022 07:41 AM
RogLat
Escape & Escape Hybrid
03-27-2017 09:22 PM
TexasGuy001
08-31-2006 07:28 PM
78fordtruck
06-04-2004 04:15 PM
Quick Reply: What’s these 2022 Superduty in trough by windshield wiper
