Coyote swap
Old Nov 11, 2023 | 12:38 PM
  #46
Jetfixer-6's Avatar
Jetfixer-6
Motormounts are less than $150 if you or your brother can weld. There are others out there but you'll pay dearly. Like $600-$700. With the money you save you can buy a welder....no BS
https://welderseries.company.site/En...BoCK-YQAvD_BwE
Old Nov 11, 2023 | 12:49 PM
  #47
Zag78F150's Avatar
Zag78F150
He can weld!! Appreciate all the help!
Old Nov 11, 2023 | 12:57 PM
  #48
Zag78F150's Avatar
Zag78F150
One other silly q. I don’t know if the existing 351m is a #s matching to truck. Where would I look on the motor to see if its the original motor? If it’s matching, should I save it just for that reason?
Old Nov 11, 2023 | 01:05 PM
  #49
Jetfixer-6's Avatar
Jetfixer-6
After I sold the truck for $35000 in less than 15 minutes, the purchaser put it on bring a trailer where it bid to $45K and he didn't sell it. He had it on his website for $54K. It was gone in just over a week. That stung a little.
https://bringatrailer.com/listing/19...custom-4x4-14/
Old Nov 11, 2023 | 01:17 PM
  #50
Jetfixer-6's Avatar
Jetfixer-6
The door tag on the drivers door will have an engine code. You'll know if it at least came with the 351M then the VIN number for a 351M engine is stamped on a machined surface on the driver's side top rear of the block. If it's a match you have to make a decision. The engine isn't on any level desirable, and I don't believe selling it will get you more than a couple hundred so again your decision.
Old Nov 11, 2023 | 01:29 PM
  #51
Zag78F150's Avatar
Zag78F150
Ok thanks. If it is in fact original motor, id probably keep it. It’s kinda like separating twins at birth, they kinda belong together.
Old Nov 11, 2023 | 03:02 PM
  #52
73FOMO's Avatar
73FOMO
Originally Posted by Zag78F150
Really appreciate you guys and all the detail u put into it. And I appreciate u answer all the probably simple questions 😁
Another q. Obviously my existing column only has D, 2 & 1, how’s that work with with the swap and 6spd tranny?
I went a more custom route. I used ‘18 Mustang GT buckets and ‘12 F150 Platinum console. I have P R N D M 2 1 and select shift on the shifter. All work as a stock ‘12 F150 would. I removed the selector and shifter from my stock column. The Dakota Digital reads what selection I am in on the dash whether Park Neutral Drive or If in manual using select shift it shows Gear 1, Gear 2, Gear 3 as I shift through the gears. Pretty slick.
Christian's1988Ford
2015 - 2020 F150
25
Oct 2, 2017 11:00 AM
thelonius
Aug 13, 2017 11:08 AM
lwk362393
6.7L Power Stroke Diesel
Jul 12, 2013 08:30 AM
thehickfarmer
18
Sep 19, 2006 06:50 PM
fitter565
Mar 31, 2004 03:12 PM
