Computer Chips & Tuners
No code?!
Old Nov 21, 2003 | 07:57 PM
AYoungblood's Avatar
AYoungblood
No code?!
I got a reman on my computer (Its sitting on my lap as i type) and it saying nothing like the codes im seeing.
Codes i see:
# - 8-4269
Cal. Code - 0900MG
On back (faces driver) there is a white sticker, it says "Dont remove" in 5 languages. And it also says "Remanufactured" in two lang's.
Also 2 small numbers on that sticker:
MSA0154
911237-78
This really makes me mad
Any ideas guys?
Thanks,
Adam
Added:
On the plastic connecter, there is something "molded" in
GTE4 and theN a small B
Another Add:
Inside connector on Red rubber seal:
E4AB-14A297-AB
Old Nov 22, 2003 | 09:04 AM
AYoungblood
You guys are killin me, 29 views and countin........
Old Nov 22, 2003 | 09:41 AM
true4.2's Avatar
true4.2
I don't even know what you're trying to ask? Are you looking for your ECU code? What are you looking for?
Old Nov 22, 2003 | 01:16 PM
FTE Ken's Avatar
FTE Ken
I'm working as fast as I can to keep up!
None of those are a standard Ford PCM calibration code. The calibration code is 0900MG and is useless so far as adding an aftermarket chip. If we could get the computer to read it there's a chance a program can be produced but my experience is that you'll need to get a PCM with real Ford code in it.
Old Nov 22, 2003 | 05:47 PM
AYoungblood
Well its a FORD PCM, its says FORD stamped in it and the sticker says something about it being "Rem'ed" by a ISO9000 manufacturer.
I know that he did (my step-dad) get it replaced, lets see.... at 112,000 so its been about 28000 miles with this new computer.
So I would have to send it in, and it sounded like there is no guarantee you could get a chip for it?
Thanks Ken,
Adam
also,
Where would I get a new box? I assume a junk yard but figured that you might know of others.
Old Nov 23, 2003 | 01:44 PM
FTE Ken's Avatar
FTE Ken
99% of the reman'd Ford PCMs say Ford on them. That doesn't mean it has Ford's code in the EEPROM. If it did, it would have a Ford calibration code on it since the calibration code sticker is required by law.
If you do a search on Google there are ton of used ECU dealers. We get ours from a company that sells used, non-reman'd ecus. This assures us that the code is Ford's code.
Old Nov 25, 2003 | 04:33 PM
AYoungblood
So.... what should I do?
Goto a junkyard?
Adam
Old Nov 25, 2003 | 11:13 PM
AYoungblood
KEN!!!!!!!
Oh.. sorry, just wanted to get your attention.
I real quick question:
Will this work?
Ford computer
Old Nov 26, 2003 | 04:48 PM
FTE Ken's Avatar
FTE Ken
WHAT?????!!!!!!!!!
Oh sorry... with the short work week I'm working overtime so I can spend the holiday with my family. Everyone wants my attention now just as much as you do. Please don't bump threads to get my attention. If I don't answer immediately its because I can't answer immediately. I answer all of them when time allows. Sometimes the forums are like being pecked to death by a duck!
If your original computer had an E9B PCM code, it will work.
Old Nov 26, 2003 | 06:17 PM
AYoungblood
Ohh its not that I was bumping the threads, i was excited to find that ECC mod. for so cheap.
My posts are at least a few hours apart.
So, i assume it isnt that code.
And i also assume im also "SOL", or is there some way to find my original code?
And thanks again, for all the help, even if you didnt say what you just did i know that your REALLY busy from reading all your other posts.
Adam
Old Nov 30, 2003 | 08:11 PM
AYoungblood
So, what should I do?
Can I find my orginal code any where?
What are my options?
I want to get a chip from you but dont know what to do next.
Adam
Old Dec 1, 2003 | 05:33 PM
FTE Ken's Avatar
FTE Ken
Sorry for the delay... my last response was tongue in cheek humor, no anger or anything like that . I took a desperately need Motorhaven vacation during the holiday.
Here's what we can do.... call your Ford dealer and give them the truck's VIN number. They can give you the original calibration code. There's a chance the aftermarket computer has that code in it. We can send a chip based on the original calibration and its a 50/50 chance it'll work. If it doesn't we'll refund your purchase and you'll just be out about $8 for shipping.
Old Dec 1, 2003 | 06:14 PM
AYoungblood
Sweet sounds good.
I am, like you going on a shorty vacation. Ill post back (prob write you email) when I get my cal code.
Thanks Ken!
Adam
boggerted
16
Feb 17, 2019 12:50 PM
Elmo154
Oct 15, 2015 05:39 PM
cowmilker08
Feb 26, 2011 04:06 PM
V8Ranger302
Nov 7, 2010 03:39 AM
boggerted
Apr 7, 2009 12:15 PM
