2020 F450 w/ Blind Side Detector, bulb out $1500
Have a 2020 F450 Lariat with Blind Side Detector. Left tail light running lamp is out, brake & flasher work ok. Checked with dealer, said it’s LED, and entire lens assembly must be replaced, cost $1500 just for the assembly. Anyone know of another option, possibly a place that can check & replace the diode if faulty?
The following users liked this post:
Quick google search showed several places you can send them in to. I have no knowledge of these places but might be worth checking out.
https://www.alledirect.com/led-tail-lights/repair
If I recall correctly, that issue on that 150 came from water entering the wiring, causing corrosion, and creating a short. Not specifically because it was LED. The electrical systems on these trucks in general are so intertwined that issues like that are possible regardless of lighting type. A halogen taillamp would also be an a network shared by many other systems and modules, and if water got in, as far as I know, it could create a similar set of symptoms.
upfix.com
williamwilliam
12-05-2021 05:50 PM
rndbroom
10-21-2020 01:07 PM
Ford Tempo Fan
10-01-2015 04:46 PM
merc546
05-29-2009 05:45 AM
