Fuel pump leaking
Old Dec 9, 2023 | 02:43 AM
Ericfromfrance's Avatar
Ericfromfrance
If i understand well. It’s better to use a thick on instead of a thin one ?
Old Dec 9, 2023 | 10:28 AM
tbear853's Avatar
tbear853
Just a caution. The thicker the carb base gasket, the easier it is to bend, break, crack the carb base with the nut tightening. Look for those with inserts at the bolt holes if going thick, they are intended to limit distortion. Never just stack plain thin gaskets!
I have for near 50 years now used plain old bearing grease on my carb to intake gasket surfaces ... it seals, keeps them pliable, and no gasket pealing sticking.
A carburetor leaking fuel at the base? Should only happen ... if it happens ... at rest with engine off if someone pumps the gas pedal ... or manually operates the linkage like when adjusting linkage.
Old Dec 9, 2023 | 03:36 PM
Ericfromfrance
so thin are better, and with grease.
Old Dec 9, 2023 | 07:06 PM
tbear853's Avatar
tbear853
The thick are OK if they have the limiting crush corner fillers in them, but if not they can be real trouble.
I favor thin and always grease them.
Old Dec 10, 2023 | 09:12 AM
Ericfromfrance
It was disconnected, what is it ?
Old Dec 10, 2023 | 09:18 AM
Ericfromfrance
The origin of the leak seems to be here
File Type: mov
Old Dec 11, 2023 | 03:51 AM
nutter3's Avatar
nutter3
It is your transmission kickdown. It should go in the blue circle, and a small cir-clip to hold it on. It downshifts your transmission when you put the throttle down hard.
adeter
Dec 24, 2022 05:09 PM
timmyboy76
13
Aug 31, 2011 05:37 PM
nlemerise
Jul 21, 2011 03:49 PM
red rock 78
Jun 30, 2010 09:22 PM
ericolicious
Apr 27, 2008 08:30 AM
