Fuel pump leaking
Old Oct 15, 2023 | 10:49 AM
Ericfromfrance's Avatar
Ericfromfrance
Fuel pump leaking
Should i replace it, or is there an another way to fix it ?
File Type: mov
Old Oct 15, 2023 | 08:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Double check the metal line connections with a wrench. And the rubber line hose clamp (?). With the motor off.....But I bet it is replacement time.
Old Nov 14, 2023 | 02:03 AM
Ericfromfrance
Finaly, i replace fuel pump, but this metal line still leaking ? is there a thing i did wrong ?
Old Nov 14, 2023 | 06:40 AM
73FOMO's Avatar
73FOMO
Worse case, if you didn’t want to replumb, you could cut the tube, add hose fittings and splice in a piece of fuel rated hose.
Old Nov 14, 2023 | 06:48 AM
77&79F250's Avatar
77&79F250
Are you sure you have the correct "flare" on the end of the metal line that connects (goes inside) the fuel pump? Also looks like you do not have the threaded part (B nut) threaded enough into the fixed nut. Where the drip is.
I would take the B nut and line out. Somehow look inside the fuel pump (with out having to remove it) and the inside of the fitting and make sure that angle matches the line end flare. Then put the line back on, push is all the way on and into the pump. Then while holding it tight on.in there and sort of wiggling it then tighten the B nut (the one that slides down the line) and try it again.
Old Nov 14, 2023 | 07:21 AM
Ericfromfrance
maybe i should order a new metal line?
Old Nov 14, 2023 | 08:58 AM
maribou912's Avatar
maribou912
Is it a new pump? I had the exact leak when I replaced mine. I went through three new metal fuel lines from LMC (none of them were an exact match to the original btw) before I realized the flare on the intake side of the pump was damaged causing the leak. Got another new pump and all went together well. YMMV.
Old Nov 14, 2023 | 09:39 AM
Olblack's Avatar
Olblack
Replace probably. They will collect moisture and rust through n leak. At least mine rusted through, I had to replace it
Old Nov 14, 2023 | 12:11 PM
Ericfromfrance
yes, it is a new pump, and i've just ordered metal line from LMC. i hope it will work??
Old Nov 14, 2023 | 06:46 PM
77&79F250's Avatar
77&79F250
Old Dec 3, 2023 | 04:13 PM
Ericfromfrance
New leak from carburetor (
New metal line: no more leaking
Old Dec 3, 2023 | 06:00 PM
77&79F250's Avatar
77&79F250
Just need a carb to intake manifold gasket. Glad to see the fuel pump is not leaking.
Old Dec 4, 2023 | 07:10 AM
Ericfromfrance
https://www.ebay.ie/itm/115931221659...mis&media=COPY
this will fit ?
Old Dec 8, 2023 | 09:34 AM
Ericfromfrance
Why is it so thick ?
Old Dec 8, 2023 | 08:35 PM
eatyourfish's Avatar
eatyourfish
They are thick to put more space between your hot intake and fuel bowl so you dont boil your fuel and have it spill into the engine
