Sponsored by: Real Truck
Ignition Lock Problem ( also PATS? )
Old Sep 21, 2023 | 07:58 PM
Marblevalley's Avatar
Marblevalley
7th Gear
Hi all, new member here
I’ve owned a 2004 f350 for a 3-4 years, had my share of problems. But this one is stumping me.
I needed a new ignition lock cylinder as mine is getting very stiff. The keys are also not in the best shape anymore .
so I order a new cylinder lock with a new set of keys ( these are the ones with transponders inside of them - I didn’t know at the time )
My old set of keys had a transponder fob on the key chain , so I figured if I kept that fob on the keychain to the new keys, no problem ? Right?
I did not disconnect the battery in this procedure , so I popped out the old ignition lock , popped in the new one and to my disbelief, the truck won’t start , lights come on but nothing.
I ended up taking out the new cylinder and put the old one back in , and it will not start with the old set now ( yes the transponder is with the set of keys when I try )
The PATS light blinks when the key is first put into the ignition , and then goes full red when It’s on the “on” position - however I’ve never noticed this before so I don’t know what’s normal.
any thoughts as to where to go from here? Did I “trip” the pats, I can’t figure this out.
Old Sep 21, 2023 | 08:02 PM
Marblevalley
7th Gear
Also, does the pats wiring have to be around the lock cylinder? Or just close by.
Old Sep 21, 2023 | 08:13 PM
projectSHO89's Avatar
projectSHO89
EDIT: Moot points. See below.
Wrong. The additional transponders will interfere with the reading of the desired one.
It's supposed to go solid for a couple of seconds and then go off. If it fast-flashes, PATS has been triggered and is supposed to disable the engine.
No, but the transceiver ring does have to be "around" or immediately adjacent to an authorized transponder so it can be read.
The '00-'03/'04 Excursion had a bit of a basturdized PATS system that tended to get glitchy at times. Someone with hands-on experience should come along and offer some insight.
Old Sep 21, 2023 | 08:16 PM
Marblevalley
7th Gear
Thanks for replying
The light stays on completely and does not go away .
It’s odd that the old cylinder and keys did not work afterwards Unless the pats completely shut down and needs to be reset ? No clue .
Old Sep 21, 2023 | 08:56 PM
projectSHO89
Wait a minute...
I just re-read that this is an F-350, not an Excursions as I originally interpreted (Thought i was in the Excursion sub-forum...). The Super Duty pickup trucks didn't have PATS back in those days. Therefore, PATS is not your problem.
Is there an aftermarket alarm or remote on this truck?
Old Sep 21, 2023 | 09:04 PM
Marblevalley
7th Gear
Originally Posted by projectSHO89
Wait a minute...
definitely has an immobilized. Maybe aftermarket…
Old Sep 21, 2023 | 09:22 PM
Marblevalley
7th Gear
I think this is the problem. When I pulled the old jammed one out I must’ve ripped these… Where do I buy this ?
Old Sep 22, 2023 | 06:12 AM
projectSHO89
You'll have to locate the "immobilizer" and identify it. That wiring is not OEM.
Old Sep 22, 2023 | 10:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Super Duty trucks did not get PATS until 2008.
Old Sep 22, 2023 | 02:02 PM
Marblevalley
7th Gear
Found out it was an Autowatch PPI 363
manufacturer gave me a factory override code while I wait for the new loop - I can also unplug it and just re jump on the ignition wire.
Old Sep 22, 2023 | 03:06 PM
projectSHO89
You'd likely be better off simply removing the system unless you see particular value in having it.
Old Sep 22, 2023 | 03:16 PM
Marblevalley
7th Gear
That’s what I think I’m going to do. I believe I would just have to find which wire is the ignition wire and reconnect it and disconnect the entire system .
4EyedTurd
Oct 30, 2024 10:29 AM
Kai Herrmann
Oct 8, 2019 07:50 PM
Doran
1997 - 2003 F150
Dec 27, 2010 05:26 PM
solareclpse2000
Mar 12, 2008 02:21 AM
agryphon
1983 - 2012 Ranger & B-Series
Dec 16, 2005 03:58 AM
