Replacing ignition lock cylinder
Old Apr 16, 2023 | 12:31 PM
4EyedTurd's Avatar
4EyedTurd
Right now the truck doesn’t require a key to start so I bought a new lock cylinder. Any chance the old lock will come out without having to get medieval on it? I’ve never had good luck replacing them in the past
Old Apr 16, 2023 | 01:03 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Without having any clue what you are working on or what is left of the ignition key lock/actuator area, I’m going to say “Sure. Why not?”
Old Apr 16, 2023 | 01:09 PM
sandymane's Avatar
sandymane
I think you have a 1993 F350 from your profile. This short video may help you get it out without getting medieval on it. Go to the second video
https://www.google.com/search?q=how+...client=gws-wiz
Old Apr 16, 2023 | 03:33 PM
4EyedTurd's Avatar
4EyedTurd
1990, that video reminded me of the pin. Thanks, had to pull the steering wheel but I got it.
Old Oct 17, 2024 | 07:37 AM
79Fuzzie's Avatar
79Fuzzie
I agree it's probably time for a replacement (and new friends). My ignition and doors don't match, which I thought might be good if I had to leave the truck running, I could lock the doors. Turns out the '79 security system is much more robust, aka the manual transmission.
Old Oct 17, 2024 | 08:17 AM
My4Fordtrucks
Hopefully the OP has it fixed by now. The thread is from April ‘23. I like having different door and ignition keys. It was that way until sometime around ‘94 when Ford switched over to a single key for all the locks.
Old Oct 29, 2024 | 03:08 PM
SurfBox's Avatar
SurfBox
Sorry y'all I forgot about my original gripe about the $60 for re-keying. Believe you me I fully understand what it takes to run an independent shop these days. For 23 years I ran Lambretta Works restoring Lambrettas, racing them, purchasing and shipping parts worldwide, etc. Total labor of love.
That said I'm going to go to another locksmith here in town that I used to use to make keys for Lambrettas. Maybe they can do it for a better price.
Old Oct 29, 2024 | 10:18 PM
97SuperDuty's Avatar
97SuperDuty
Yeah, a bitter pill to swallow, you can get new ignition keys with the ignition lock and those are easy to replace on the column, but in order to get the doors to match the ignition you will need to get the door locks re-keyed, and that will only work on certain years, as Ford made them some years where the ignition and doors intentionally don't match. I'm not sure what the logic is behind that. On my '97 I had the doors rekeyed to match the ignition, but I ended up replacing the ignition and now they don't match anyway...go figure...
I'm probably dating myself, but many of the car manufacturers, including Ford, used a round key handle for the doors and a square key handles for the ignition, even though the keys were the same. Maybe it's a prevention for getting into an accident? If you can't get in and start your truck, you can't get into an accident.
Old Oct 30, 2024 | 10:01 AM
SurfBox's Avatar
SurfBox
Go ahead and date yourself, I've been doing it since so-and-so left me...
I have an '82 Chevy(!) motorhome that has the two different keys approach from the factory. Pretty sure my first car ('73 Vega) had two keys also. Must be predominantly a GM thing, with Ford only venturing to the dark side only occasionally. My '94 F150 had one key and I loved the simplicity.
I'll probably buy the LMC ignition lock and have it re-keyed to match my doors. Hopefully it will be decent quality like others have said. I'm guessing most of what LMC sells is the same as Dennis Carpenter stuff, yeah?
Old Oct 30, 2024 | 10:29 AM
Jim_K's Avatar
Jim_K
Can't speak to the differences with regards to ignition and door lock cylinders, but lately I've been noticing a lot of LMC stuff has been pretty cheaply made (Chinesium?).
If it were my truck I'd pay the premium price and buy from Dennis Carpenter.
(I have no relation to either company, just my observations.)
Grandpa's66
Apr 11, 2021 04:46 AM
Kai Herrmann
Oct 8, 2019 07:50 PM
Late96
2004 - 2008 F150
Jan 21, 2015 04:23 PM
chuckyl
Jan 13, 2012 10:14 AM
