Inner Tie Rod Question
Old Sep 16, 2023 | 11:59 AM
DFWF150's Avatar
DFWF150
95 F150 4WD 5.0L. Replacing both inner tie rods. Got new Moog parts. Might be a stupid question but I searched and can't find the answer. Passenger side OEM tie rod has this safety latch thing (I assume that's what it is to keep adjusting sleeve in place?). See attached pic. New part does not have it. Is it needed? Did I get the wrong part? Is it possible to remove it from the OEM and put it on the new Moog tie rod, assuming I need it?
Thanks
Old Sep 16, 2023 | 01:03 PM
jas88's Avatar
jas88
I always cut those off when I find them. They get in the way and I don't see the point unless you like to leave your tie rod couplers loose.
Old Sep 16, 2023 | 01:10 PM
DFWF150's Avatar
DFWF150
Thanks. I couldn't really tell the point of them either. Good to hear I'm not going crazy and I can press on with the new tie rod.
Old Sep 17, 2023 | 03:27 PM
manicmechanic007's Avatar
manicmechanic007
Ford just wanted that one tie rod sleeve clamp to be in that position
I used to cut them off too, and just put the sleeve clamp where I wanted it
deltabowhunter
Apr 17, 2022 03:14 PM
waldreps
2004 - 2008 F150
Jul 18, 2017 12:59 PM
kbc4245
Jun 18, 2013 04:29 PM
bartn98
Apr 19, 2009 07:35 PM
_GEEZER_
Jan 31, 2004 07:08 AM
