351 noise identification
Old Aug 15, 2023 | 09:05 PM
Truckbuck's Avatar
Truckbuck
This video is a week or so old, but this is my 88 351w, I have no idea why it is making this noise, I thought it was rod knock initially, but all the rods and wrist pins don't have any play in them.
I am pulling my hair out trying to find out what this noise is any help would be greatly appreciated.
File Type: mov
Old Aug 15, 2023 | 11:53 PM
Truckbuck's Avatar
Truckbuck
My guess so far is either predet, or a lifter is about to explode at this moment, I think the pistons are good.
Old Aug 16, 2023 | 05:30 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What is a “predet?”
Old Aug 16, 2023 | 07:23 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
What is a “predet?”
It's a made-up term that some people use. The full misnomer is "predetonation" which has no meaning whatsoever and is a blending of the words "preignition" and "detonation"; both of which ARE actual terms and conditions but are completely different in how each is created. I guess "predetonation" is a way to cover both scenarios without actually knowing what is happening.
Old Aug 16, 2023 | 07:27 AM
Truckbuck's Avatar
Truckbuck
Yeah I am leaning away from it, considering how the spark plugs are new and its only one cylinder doing it, and I used fresh gas, the timing was correct and all the spark plugs are matched up per the dizzy.
Old Aug 16, 2023 | 11:06 PM
Truckbuck's Avatar
Truckbuck
Do you guys think it could be rocker arm, it seems way to loud to be a lifter to me. The rocker arms were very well broken in, I could barely feel the oil journals with my fingernail, I will take off the valve covers and see what is going on under those things.
Old Aug 16, 2023 | 11:12 PM
OBSession05's Avatar
OBSession05
Could very well be. Only other thought I had was maybe you had a valve get smashed into the piston. That's my only guess at this point. Good luck!
Old Aug 16, 2023 | 11:40 PM
Hit Man X's Avatar
Hit Man X
Pull driver valve cover and nose around as it is easy.
Old Aug 17, 2023 | 07:47 AM
Truckbuck's Avatar
Truckbuck
I will poke around in there today and see what if there is anything that looks like it doesn't like the motor.
Old Aug 19, 2023 | 01:08 AM
Truckbuck's Avatar
Truckbuck
Alright I pulled the covers, some of them had a little play in them, maybe a 1/8th inch, I don't really know if its causing the problem. I figured I will just replace them, I am gonna look inside the pistons tomorrow and see if there is evidence of the valves hitting the piston.
Old Aug 19, 2023 | 11:28 AM
OBSession05
Very possible one or many of the rockers were making all that clatter. I haven't seen them just come loose like that but it isn't out of the realm of possibilities. Might double check for broken springs. Once again I'm just guessing here but that's one of many possible outcomes.
Old Aug 19, 2023 | 02:23 PM
Truckbuck's Avatar
Truckbuck
The springs are intact, I am going to retorque the rocker arms and make sure they are not loose
Old Aug 19, 2023 | 10:36 PM
Truckbuck's Avatar
Truckbuck
UPDATE:
I pulled all the plugs today and used a bore scope and there is no evidence of the valves hitting the piston.
I also got a socket and a extension on the connecting rods and with some force I got some play out of all of them not a lot but enough to where I could feel and hear it, I am going to get a re ring kit and going get new bearings and just rebuild it unless I can find a rebuilt block soon, I unfortunately need the truck ASAP and this is the fastest way as of right now.
Old Sep 17, 2023 | 03:19 PM
Truckbuck's Avatar
Truckbuck
UPDATE:
Never gonna believe this, somehow a sheet metal screw ended up in cylinder 7. Upon further diagnosis all the bearings are just copper, no overplate, the block was pitted, and so worn the machine shop had to bore it out to 30 over and had to sleeve the one cylinder that was pitted, I knew the block was worn, but I didn't know it was that bad.
Old Sep 17, 2023 | 04:32 PM
OBSession05
UPDATE:
That is the craziest thing I've EVER heard but sometimes it just happens. No idea how in the hell a screw like that got in but definitely wasn't helping anything. I've heard of people dropping carb parts into an engine and ruining it but never a sheet metal screw. Glad you found it and good luck on that build.
sum_weirdo
Jun 3, 2023 08:54 PM
CHADCLOSE
6.7L Power Stroke Diesel
Apr 10, 2021 03:17 PM
circllb
Nov 28, 2017 10:39 PM
