Question : Tie rod ends
I went to order tie rod ends online for my '89 Bronco and there are four different types listed. Right inner, Right outer, left inner, left outer. What the hell does this mean?? As far as I know; I only have two rod ends the one on the tie rod, and the one on the draglink? Why are there four listed, and which ones do I need??
(accordian) sleeves. These are on vehicles with rack and pinion steering. I was told that cars without rack and pinion, may also have inner and outer depending on the steering configuration.
I left the inner tie rods to the specialists; you also need a special tool, but it is possible to do it yourself. You'll have to jack the car up and see which tie rods are loose by moving the wheel back and forth horizontally while watching the steering. A second person is helpful to move things; while you watch.
