Can My 2019 Be Retrofitted With A Puck System Bed Hitch
Old Sep 3, 2023 | 11:31 PM
Bananasfoster's Avatar
Bananasfoster
DEPLOY TRUNK MONKEY
Question Can My 2019 Be Retrofitted With A Puck System Bed Hitch
I'd like to lose the B&W Turnover Ball that I have a B&W Companion in on my 2019 F350, and go to the puck system I have in the 2023 F450
Anyone retrofit a bed with a puck style hitch?
Old Sep 3, 2023 | 11:37 PM
4wd6.7L's Avatar
4wd6.7L
Quite a few have added the 5th wheel prep hitch after delivery. There are some good videos outlining the process. The one thing you might find is that the center hole that was drilled for the B&W might not be in the same exact location as the Ford hitch. Close though.
The use of a lift isn't necessary but here is a good video.
https://youtu.be/Zvf5Y4DWySo?si=uA2pGhNyc1Wqnijn
Old Sep 4, 2023 | 06:46 AM
Baja Fog's Avatar
Baja Fog
70 year old me and my 65 year old wife did the install ourselves. Well, our next door neighbor helped lift the bed off and on. Went by the YouTube video, but you really don't have to. It is very straight forward.
Unbolt the bed from inside.
Unplug the wires behind the bumper.
Remove the tailgate.
Lift the bed off and drill puck hose.
Bolt on puck kit ($750 kit from Ford, though I found one used for $500).
Lift the bed on. Plug in the wires and bolt it in.
Old Sep 4, 2023 | 08:42 AM
Bananasfoster
DEPLOY TRUNK MONKEY
Thats very encouraging. Thank you guys.
I would like my bed back in the 19, but would like to have the emergency ability to pull the B&W Companion puck out of the 23 and slap it in the 19, roadside if my 23 blows up at 10K like some are mysteriously prone to do.
We caravan with the 23 pulling the 5er and the 19 as the chase vehicle, beach vehicle, emergency 2nd tow vehicle.
This will help me..........AS LONG AS THERE IS NOT A FAKE SUPPLY CHAIN SHORTAGE OF THE PUCK HITCH KITS which is the next thing I will be finding out this week.
Old Sep 5, 2023 | 11:59 AM
acdii's Avatar
acdii
The only thing to be watchful of in lifting the bed is do NOT go straight up with it. The lower front corner of the bed side curves under the cab, so you have to lift and move a few times so the corners clear, then you can go straight up. I used forks on my tractor to remove the steel bed off my 2012, which can go straight up, by slipping a pair of 2x4 under the bed rail and resting them on the forks. A strap from the fork frame to the front be rail kept it from tipping.
Old Sep 5, 2023 | 04:47 PM
Bananasfoster
DEPLOY TRUNK MONKEY
Wonder if the guys at the dealership know this, or if they messed up a few trucks learning.
Old Sep 5, 2023 | 05:06 PM
Joe T's Avatar
Joe T
I have got a whole 8ft long bed with a weatherguard pipe rack on it off myself, like my own 2 arms. The aluminum bed is light as heck.
Long story short you can get the bed on and off in a couple hours. Just inch it back as mentioned.
Help is handy, but no exaggeration they are really feather light.
Old Feb 16, 2026 | 08:46 PM
Elliott Tyler Yates's Avatar
Elliott Tyler Yates
3rd Gear
Retrofitting to the puck style
Were you able to retro fit to the puck style?
I have the B&W turnover in my ‘19 SB and would like to go to the OEM puck style but have found that the hold for the B&W and OEM are around 3/4” off in location according to google. Any update would be greatly appreciated before I ordered the puck setup and drilled the four corners.
Benztechnc
All Things Towing
16
Jan 15, 2021 11:04 AM
ClineFarms
Dec 24, 2019 01:38 PM
Jace2016
Oct 28, 2016 07:34 AM
Deluxe06
All Things Towing
Oct 24, 2014 11:33 PM
