Sponsored by: Real Truck
AC solution?
Old Jun 3, 2020 | 06:50 PM
QUINCE's Avatar
QUINCE
AC solution?
My 12 years old AC is slowing down considerably; it takes 15-20 miles to feel some relatively cold air. What is the cheapest solution to get it back? Truck is a 2007 F350 6L 4x4. The AC was the only "luxury"; manual transmission, crank windows.... as my old boss said when I bought it "You went back 20 years". I said "Yap, and 15k cheaper.
Thanks!
Old Jun 3, 2020 | 07:05 PM
ford390gashog's Avatar
ford390gashog
First step is to put actual gauges on the system. Then diagnose further.
Old Jun 3, 2020 | 08:48 PM
QUINCE's Avatar
QUINCE
All I have is a ScanGauge II but I assume you are talking about pressure gauges or so right on the AC system. Is there a procedure listed here somewhere? List of potential problems maybe?
Old Jun 3, 2020 | 11:57 PM
AK4x4's Avatar
AK4x4
You need someone with A/C gauges and a R-134a Temperature Pressure Chart. Find the current ambient temperature then check the gauges vs. the referenced high and low pressures for the relevant temp listed on the chart. Something isn't right, my 2005 has good A/C function. Russ
P.S. not necessarily relevant to your stated symptoms but an EGR delete can affect your A/C if nothing was done to address the cooling fan issue
Old Jun 5, 2020 | 04:26 PM
HearseDriver's Avatar
HearseDriver
Not sure about an 07 - BUT was your truck run in dusty conditions? My 06 the evaporator was packed with dust & dirt. Believe it or not it wasn't all that bad a job to get to. The passenger inner fender well comes out and the evaporator case splits in half giving easy access to the evaporator but my 06 is the 6.8 V10 a set of harbor Freight A/C gauges will be able to give you the high side readings to let you know. My 06 was a farm truck running through the fields most every day and the evaporator was packed with dirt.
Old Jun 6, 2020 | 05:53 AM
projectSHO89's Avatar
projectSHO89
Just be aware that it only takes a few ounces of refrigerant in the system to "pass" this "test". Not terribly useful for diagnosing performance issues.
A "dirty" evaporator will cause a loss of airflow volume and velocity, it won't have an effect on the performance of the cooling function which appears to be at the root of the OP's issues.
^^This^^^ Anything else is just a guess and the odds of it being the right guess are not that good with the minimal description provided.
FordPickMeUp
May 25, 2022 02:32 PM
Brandon Cloud
Jan 24, 2020 04:56 AM
galaxie223
Jul 31, 2003 09:20 PM
