A couple E4OD questions
I recently took possession of Dad's truck. The 1996 mentioned below in my signature. He bought it back in the early 2000's and last year, when we had to take away his drivers license, they transferred the title to me. Dad passed away in February and I went and got the truck around the first week of this month.
So, my first question... How hot is too hot? We put the standard gauges in (boost, EGT and TFT) when Dad bought the truck. The TFT probe is in the test port. E4OD transmission, of course. At the time, we were never able to figure out what the upper limits of transmission oil temperature were.
The temp rarely even gets high enough to move the needle, which starts at 140. When shifting a lot or running without the torque converter locked it starts to climb, but I don't think I've ever seen it break 250, or maybe even 230. I can swear by that. Other than the 265 mile trip back from E. Oregon bringing it home, it's been a long time since I've driven this truck much.
Anyway, I'm wondering what I should be on the lookout for.
The other question, the one that got me started on this whole thing, is does the TCM or ECM do any adaptive learning. Dad always had a problem with slow parasitic drain on the batteries when it sat for long periods of time, so he installed a set of battery cut off switches on it. I use a battery maintainer on the 2004, for the same reason, slow parasitic drain. I'm thinking I'll probably do the same with Dad's, but I'm not sure. If there is any adaptive learning going on, the battery disconnects are a bad idea.
Thanks guys.
they will discharge if your battery terminals are corroded and sometimes with a loose ground
some cleaning tips
https://www.ford-trucks.com/forums/1...ou-cranky.html
some cleaning tips
The maintainer requires me to run an extension cord out to the truck. The disconnects make me open the hood every time I want to use it, and again when I'm done.
do the cleaning
try the test
i would look to see what is draining the batteries after the tests
dont need disconnects, can wire in a GPR to keep them separate, campers do that often
You can run the transmission up to 220°F all day long with no problems. You can go up to 250°F for up to 1/2 hour at a time,
I doubt this truck is going to see that kind of work again. Other than the occasional job of helping relocate an RV in the park, it's most likely going to be a propane hauler.
