Need torque specs ASAP please
Old Dec 3, 2006 | 01:45 PM
RotGrubestier44's Avatar
RotGrubestier44
Hey guys! I'm working on a 95 F-250 xlt 4x4 w/ a 7.3L Powerstroke, E4OD automatic, 240,000+ miles. We are replacing the injectors, glow plugs, and valve cover gaskets. I need to know the torque specs for the all of the fasteners that hold on the above. If somebody could post those up ASAP it would be much appriciated. I might even give you a cookie! Thanks in advance. Search feature isn't working btw.
Old Dec 3, 2006 | 08:55 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Injector Retaining bolt - 10 ft-lb. Oil Deflector bolt - 10 ft-lb. Oil rail drain plug - 53 in-lb. Glow plugs - 14 ft-lb. Valve cover bolts - 18 ft-lb. Hope this helps.
Old Jul 27, 2023 | 09:08 PM
OBS-MD's Avatar
OBS-MD
Trailering
And 16 years later, your reply helped someone else out! All the torque specs I need for tomorrow's injector o-ring replacement. Thank you!!
Old Jul 28, 2023 | 09:25 AM
knottyrope's Avatar
knottyrope
Injector Retaining bolt 120 inch pounds and use an inch pound wrench, foot pounds wrenches are not accurate that low
