Starter bendix issues.
Old Jul 15, 2023 | 10:07 PM
Jdeshler's Avatar
Jdeshler
Need some help from the wise. Ive had 2 FE starter motors act up this week and I have no clue what to do with them. They buzz when power is applied but will work correctly when the bendix cap is removed and the bendix is depressed slightly. The drive gear is clean and free of debris and the brushes are in good shape.
My battery is confirmed hot 800CCA. The magnetic field will not overpower the spring for some reason.
Is there a way to shim the bendix down closer to the starters armature or is this a sign of a needed replacement? TIA
Old Jul 17, 2023 | 09:18 AM
Jdeshler's Avatar
Jdeshler
bump for more intelligence
Old Jul 19, 2023 | 10:28 AM
Jdeshler's Avatar
Jdeshler
New starter it is 😅
Old Jul 19, 2023 | 01:13 PM
mark a.'s Avatar
mark a.
Did you ever try tapping on it with a hammer to see if it would take off ?
Old Jul 19, 2023 | 06:34 PM
Jdeshler's Avatar
Jdeshler
Yes, i also completely disassembled them with no luck. Whatever the magnetic field is that is generated doesn't seem to be strong enough to engage the bendix
I'm certain I have something wrong. I know the gasket on the cover acts as a shim that presses the bendix to a certain depth.
Old Jul 19, 2023 | 11:12 PM
mark a.'s Avatar
mark a.
I'd put a new starter drive in it.
The cover has nothing to do with it, the gaskets are all the same.
Old Jul 20, 2023 | 09:56 PM
Jdeshler's Avatar
Jdeshler
Yeah, got a new one on the way. Thanks dude!
PROSTOCK
Jun 27, 2023 10:59 PM
AllenV
Apr 26, 2023 02:09 PM
Anoymousjoe4126
Large Truck
Jan 20, 2023 11:29 PM
f1barry
Jan 14, 2020 08:04 AM
Spktyr
55
Dec 28, 2016 08:56 AM
