White smoke when accelerating from a dead stop.
Old Aug 3, 2023 | 06:18 PM
BryanStein's Avatar
BryanStein
Originally Posted by 99FordGuy
LOL.. But I love this truck
BUT, "I love it long time." I've got seconds behind IHCC.
IHCC has listed the correct checks. If you boost is still what it used to be (20 TO 22 W/O a tune), you don't have a cracked Y pipe.
Check the smell of the smoke. If it smells like oil, it is likely the turbo seal.......especially considering the low mileage. It probably dry rotted.
But, if you don't want to mess with it, I'm sure there will be some interest at that mileage.
Old Aug 13, 2023 | 10:45 AM
99FordGuy's Avatar
99FordGuy
Update: Still no smoke and still better boost than before with less throttle. Truck is running great but I have noticed one thing, between 1500 and 1800 rpm under light throttle I have noticed a low pitched whistle that I never noticed before. Could the new Y pipe cause that? I re-checked all the exhaust clamps and everything is good and tight.
Old Aug 13, 2023 | 12:10 PM
IHateCommieCars's Avatar
IHateCommieCars
Good news! If it requires hearing, I can't help much. However, I've read that some types of turbos whistle. Maybe it's the rebuild kit, turned it into a whistler. But, yeah, it could be a small air leak as well. Maybe a crack in a boot that's not visible.
Old Aug 13, 2023 | 12:15 PM
diesel_dan's Avatar
diesel_dan
Does the whistle change tone as the RPM changes? I hear my turbo way more at lower RPMs but the whistle is always changing as RPM/throttle changes - A fine working VGT is what that is...
Old Aug 13, 2023 | 12:52 PM
99FordGuy's Avatar
99FordGuy
Yeah it does change as the RPM changes and stops as soon as I let off the throttle. I only hear it between 1500 and 1800 and only when I give it light throttle. The boost looks good and the throttle response is great.
wburge
6.4L Power Stroke Diesel
31
Nov 25, 2013 04:49 PM
79 Stepside
Dec 29, 2011 08:11 PM
bruno6491
Mar 5, 2008 07:49 PM
adambomb
Feb 25, 2007 12:05 AM
dagren99
Jan 26, 2006 05:50 PM
