White Smoke
Old Jan 26, 2006 | 12:44 AM
dagren99's Avatar
dagren99
Unhappy White Smoke
Ok Guys Here's another White smoke thread - I looked through the Thread at the top of the page but, mine has a slight twist to it.
Here we go:
1. Start Truck (34 deg this AM) - starts fine, no romps, no rough idle, no white smoke.
2. Let truck warm up for a few minutes - no white smoke
3. Drive away - No smoke
4. 1st stoplight - Tons of white smoke while stopped - It looked like a mosquito Fogger was attached to my truck!
5. Green Light - Drive on - Smoke goes away after about 100yds
Plans - based on what I read in the Sticky thread:
1. Check GPR - Mine is the Orig (about 5.5 years young)
2. Check GP resistance - Orig GP's as well
3. Check Valve cover connector pins for Damage/burning or discoloration
One thing that's buggin me - If I have bad GP's or GPR - Why don't I have a starting problem? One other thing that may or may not be related to all of this: I replaced my Fuel Filter right before this started - this was my first trip since changing it Tuesday night. Could I just have some residual air in the fuel system that's causing the smoke? Or, is that just wishful thinking on my part?
DG
Old Jan 26, 2006 | 08:04 AM
Kwikkordead's Avatar
Kwikkordead
Your problem is 100% NOT your glow plugs. You are right about wondering if it would start at all.
Done the CCV Mod? I'm wondering if you have an intercooler full of oil and it's getting blown into the engine.
Edit: I just read your post again and your question about the fuel filter is valid. I've had my truck smoke more when purging the air as well, but not enough to be called a mosquito fogger.
Old Jan 26, 2006 | 01:07 PM
schmity's Avatar
schmity
Check your turbo for shaft play. Mine also started blowing smoke when coming to a stop. Two weeks later, and my turbo was shot. If it is your turbo, the smoke will be greyish blue and smell like burn't oil.
Old Jan 26, 2006 | 01:08 PM
PSNut's Avatar
PSNut
Here we go:
DG
Does the white smoke happen at the first stoplight only?
Old Jan 26, 2006 | 01:34 PM
StrokedRanchero's Avatar
StrokedRanchero
I would take your fuel filter back out and re-install it, making sure it's seated correctly.
Old Jan 26, 2006 | 05:50 PM
RushN350's Avatar
RushN350
KWICKK is probably right. If theres no noticable drivability issues I would just wait and see if it stops.
donfordman
Sep 18, 2014 07:01 PM
Triplespeed
Aug 24, 2013 06:42 PM
Dutch Semi
Aug 20, 2011 06:21 AM
n20
43
Dec 10, 2009 11:30 AM
bdrummonds
20
Dec 20, 2008 01:41 PM
