blowing blue smoke
Old Dec 28, 2011 | 07:14 PM
79 Stepside's Avatar
79 Stepside
blowing blue smoke
Last week started 05 without any mods pure stock. Wasn't pulgged in temp around 35. Started up blew blue smoke about 3-5 mins. then cleared up, no smoke rest of the day. I was due for oil change always ran 15w40 rotella all the time. I ordered a bottle of hot shot secrets & bought the T6 5w40. Well for christmas i got a scangauge ll & a fumoto valve. Monday changed oil added HHS & fumoto valve . Hooked up SC ll. Ran truck down the road about 5 miles all of a sudden at a traffic light truck was dumping blue smoke like crazy.Then truck sounded like it was running smoother & smoke stopped. So i ran it about 30 miles down highway ran fine with no smoke. Tonight i started truck up not plugged in temps 30 started smoother but blew a cloud of blue smoke about 3-5 mins. after that smoke settled down but continues to smoke alittle bit constenly. Any ideas please.
Old Dec 29, 2011 | 12:05 AM
BLADE35's Avatar
BLADE35
could be a turbo seal going out
pull the down pipe and check for an oil swirl inside that end of down pipe
Old Dec 29, 2011 | 04:31 AM
bismic's Avatar
bismic
Pull and clean the EGR valve also. Smoke color is sometimes hard to envision over the internet.
Old Dec 29, 2011 | 07:54 AM
ljutic ss's Avatar
ljutic ss
Next time you start your truck when it's cold and it starts smoking at idle, check the smoke odor for a sweet smell (coolant) or diesel fuel smell (injector) or oil smell (turbo seal)
Old Dec 29, 2011 | 03:30 PM
BRay09's Avatar
BRay09
Mine starts rough after a cold night and blows blue smoke for a few seconds and then quits. Due for an oil change now and will change to rotella t to see if that's going to help.
Old Dec 29, 2011 | 06:11 PM
79 Stepside
I will check the egr . I pulled it last year ,it had alittle build up ,but pretty clean from what i read others looked like. I would post a pic. but don't know how on the smoke. Truck has 143,253 miles on it.
It just smells like exhaust.No sweet,diesel or oil smell . Smells just like my JD tractor and smokes like my outdoor wooburner lol. I talked with Lubrication Speciaties today. He said it is normal to smoke blue like that for the first 300-500 miles then should clear up . It's just doing it's job right now. It should clear up after that. Problem is I only put about 5000 miles a year on the truck. I'll have to go on a road trip I guess. I'll keep everyone posted, Thanks for all the helpful replies. I still would like to know how to post pics. Thanks again.
Old Dec 29, 2011 | 06:29 PM
cheezit's Avatar
cheezit
some smoke from cold cyclinders is normal. an engine that runs poorly is not.
Old Dec 29, 2011 | 08:11 PM
79 Stepside
Sorry for the delay . Do u think i may have problems? I'm going to try this weekend to pull the EGR recommend earlier & look at it. If I don't get called out I'm on call . I'll try to possibly remove down pipe also recommended .Don't what kinda job that will be have only ever pulled EGR,changed filters and fulids , rear brake job & had fcim rebuilt.
BCPowerstroke
Jun 8, 2019 07:24 PM
mayhem2k7
Apr 24, 2015 06:45 PM
john510
Oct 1, 2014 12:41 PM
460supercab4x4
Oct 29, 2006 05:39 PM
ceprice
4 Cylinder Engines
Sep 28, 2004 09:13 PM
