Pulled injector
Old Jun 23, 2023 | 09:23 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Pulled injector
I pulled the passenger side closest to the front bumper injector. CCLB with 260k miles, likely original injectors. Looks like some built up heat over time maybe. Is this brown spots normal for older injectors? Truck has been running fine but I pulled the injector because I needed access to the area. I got my compression test connect stuck on the glow plug adapter. See pics of injector, any concerns?
Old Jun 23, 2023 | 09:37 PM
Harveyearlolstad
Also, could I put this injector back in without replacing the orings, until I replace the injectors in 6 months? I don't have any orings right now
Old Jun 23, 2023 | 11:04 PM
96SD's Avatar
96SD
I personally would not put that injector back without new orings and a new copper washer. But my luck is terrible you may have great luck.
Old Jun 24, 2023 | 07:38 AM
ESwift's Avatar
ESwift
CNCFAB
I would do new orings and washer.
Or since things are open already, do the new injectors ahead of schedule :-)
Old Jun 28, 2023 | 07:48 AM
joshh's Avatar
joshh
while I don't recommend it I have reused injector orings/washers for a short period with no noticeable damage done afterwards
take that info as you wish
Old Jun 28, 2023 | 08:28 AM
97-psd's Avatar
97-psd
That is a touchy subject. Many stand by the idea that any injector removed gets new orings when reinstalled. Could you do it? Maybe. There are so many variables it is hard to give a solid answer either way. If it were mine, I had a plan to replace them soon, and I wasn’t driving it much I would probably do it. If you are planning a 1000 mile trip, I wouldn’t chance it.
Old Jun 28, 2023 | 08:48 AM
z31freakify's Avatar
z31freakify
I've reused O rings and washers, havet had one failed, but yours are still the factory O rings that left the assembly line 25± years ago, might as well change them out.
Old Jun 28, 2023 | 12:09 PM
Exwhyze's Avatar
Exwhyze
Let's say you re-used the O rings and it started drinking oil.. you'd be cheaper off in the long run replacing the o-rings versus adding oil regularly for 6 months.
jaimesone
Aug 26, 2021 07:40 AM
uglypitbull
Sep 30, 2020 09:10 PM
Yahiko
Jul 4, 2014 06:54 PM
RacinNdrummin
35
Nov 20, 2012 12:59 AM
takotruckin
Aug 9, 2010 02:33 PM
