Injector copper washers
Old Jul 4, 2014 | 02:45 AM
Yahiko's Avatar
Yahiko
Ok so what way do you install the copper washers onto
the injectors?
Do I want this to or away from the injector?
Injector seal kit Ford
Sean
Old Jul 4, 2014 | 05:54 AM
npccpartsman's Avatar
npccpartsman
I was told it made absolutely no difference.
Old Jul 4, 2014 | 06:46 AM
texans's Avatar
texans
It dosent matter. I never pay attention to the orientation when installing injectors.
Old Jul 4, 2014 | 08:41 AM
run6.0run's Avatar
run6.0run
I disagree guys,,, the raised middle ring goes down. I'm sure it will crush all the same,, but every new injector I've gotten has them like that. There are two raised rings that touch the injector,,, and the single raised ring touches the Inj cup. However I remember wondering the same thing a long time ago,, and I've successfully installed them both ways,, but the new injectors are all like described above.
Old Jul 4, 2014 | 11:30 AM
cheezit's Avatar
cheezit
Ok... it really does not matter.
That said imo they should be installed with the rasied part faceing the injector cup.
Old Jul 4, 2014 | 11:46 AM
npccpartsman
I agree with you and Anthony and that's the way I always install mine too.
Old Jul 4, 2014 | 12:17 PM
vloney's Avatar
vloney
raised part facing the cup, and use a 10 mm deep socket to "drive" on the washer.
Old Jul 4, 2014 | 12:41 PM
BLADE35's Avatar
BLADE35
right agree they only go on way
the ridge looks more Pronounced in the pic then they used to be a few years back so are they Updated??
Old Jul 4, 2014 | 02:12 PM
Yahiko's Avatar
Yahiko
Thanks everyone. Have a fun and safe 4th.
And get a driver if you have had too much of and are
Benny the kit is a Ford kit and that is all I know about
it being updated or not.
Sean
Old Jul 4, 2014 | 06:01 PM
texans's Avatar
texans
I agree there is a certain direction they are supposed to go, but at the end of the day it really doesn't matter. Either that or I have just gotten lucky, and the hundreds of them I've installed, without reguard to direction, have just ended up the correct way. I dought that.
Old Jul 4, 2014 | 06:54 PM
BLADE35's Avatar
BLADE35
they seal either way
I think the big thing is a Clean injector Cup & Injector where the copper washer seals
My thinking was
The Combustion Side seals on the Inner Edge of Copper wqsher
The Fuel Side seals on outter edge
This way the Combustion/fuel seals on the edge/point of the Copper washer it would enter First
theres been enough injector jobs over the years that if it was a immediate problem or problem at all we would know it. Its probably the case where the washer seals tight enough under torq 24-26 ft/lbs its crushed enough to not matter much
johndeerefarmer
Jul 24, 2016 07:13 AM
cabloom300
Nov 10, 2013 06:26 PM
ltl_jrw
Jun 27, 2011 11:29 PM
JamesHajek
Oct 19, 2010 12:34 AM
paintslinga2010
Nov 16, 2008 12:08 PM
