7.3 Godzilla issues
Old Jun 4, 2023 | 07:13 AM
Tam123's Avatar
Tam123
2nd Gear
7.3 Godzilla issues
Hello,
I’m a first time poster but wanted to seek some opinions or advice on here from people with more experience and knowledge than me. I’m in the market to buy a 3/4 or 1 ton truck for our families travel trailer. I’ve talked to many friends and read quite a bit about gas vs diesel and decided I wanted a gas 3/4 as I’m not pulling often enough or heavy enough to justify a diesel. I mostly want a safe tow vehicle that’s reliable and can get the job done, I don’t need to tow 20k lbs.
I ordered a 2023 7.3L gas f250 and it’s basically ready to be picked up at this point. Over the last month I’ve seen so many problems online, especially YouTube, with engine failures with the 7.3 (especially under 30k miles). I’m starting to second guess the decision. I had a suburban previously and had to replace the engine at 100k miles due to lifter issues and a few other things which made me swear off buying a GM product again. Now I’m reading the same thing with ford at even fewer miles. Is everyone else seeing these same things or experiencing engine problems with the 7.3? I honestly don’t know what truck to buy
Old Jun 4, 2023 | 07:20 AM
elee3's Avatar
elee3
The guys on here that have 7.3s love them. I haven’t heard these stories about failures. That being said, it’s pretty easy to find horror stories, about any product, on the internet. Buy your truck and enjoy it.
Old Jun 4, 2023 | 07:26 AM
mapitts66's Avatar
mapitts66
2020 F250 here. 7.3 with 3:55's. I pull a 9000 pound 5 the wheel with not probems. A little over 18500 on the odometer. Pulls like a champ. No problems what so ever. If you spend enough time on Youtube, you will never buy another vehicle ever.
chadstickpoindexter's Avatar
chadstickpoindexter
It seems like a lot of folks here are having good experiences with the 7.3 (and for the record, I have a 22 6.7). You can go over and look in the 7.3 specific section to see what folks are talking about there specifically, but the most I have seen in the 2017 section is more folks tend to complain about the 7.3/10 speed pairing than anything else. Honestly, ALL of these motors are great, however, any of them can experience troubles. None of them are exempt from it. The best advice is to take care of whatever engine you get. Stay on top of maintenance, and don't let a dealership do it. It's best to do it yourself since you know it was done correctly and with the correct supplies, plus, it will cost you less! Try and learn at least some about the engine and watch for signs of something not going right. Catch it early if you can and take care of it then... don't keep driving it and worry about it later. Anyway, go get that truck, and enjoy it! I'm sure like the rest of us here, you will love your Super Duty!
Old Jun 4, 2023 | 08:02 AM
scraprat's Avatar
scraprat
Top Answer: 5
I have 103k miles on my 21 and it is running fantastic.
YouTubers have to make it seem as the word is ending, everything is junk and ready to explode or everyone is naked to get views for money.
Even on this forum there's threads parroting the garbage of what they saw on you tube or a friend of a friend's uncle brother mechanic buddy said something but very few actual owners with the failures. Not saying that there are not failures just not every engine is prone to blowing up.
Old Jun 4, 2023 | 08:09 AM
RidgwaySD's Avatar
RidgwaySD
Problems are exceedingly rare on the 7.3 engine. My 2022 has almost 65k on it now and never missed a beat. Others are over 100k with no problems. The lifter "problem" is pretty overblown. There are probably close to a million of these engines on the road today and a small handful have failed, like any engine. The same talk was out there when I bought mine, didn't even slow me down, the 7.3 ten speed is a great combination in these trucks. It is a far better choice than the Ram 6.4 and I think better than the GM 6.6. It pulls better than either for sure.
Old Jun 4, 2023 | 08:56 AM
Poncho450's Avatar
Poncho450
No matter the motor or the brand all you're going to see if you search online are the problem children. Not many are going to post about their miles and miles of trouble free service. Look for trouble online and you'll find it in seconds.
That being said, last fall I sold a nice 2005 Lincoln LS for the same reasons. Kept reading of how finicky they are, hard to work on many aspects yourself, limited parts availability, etc. That started nagging thoughts in the back of my mind that I was driving a ticking time bomb. So I sold it while everything was working perfectly.
But at that point I'd already replaced all 4 spring/shock units myself along with upper control arms. To change the transmission fluid and filter was a very convoluted process that I took it to a dealer for just to have peace of mind.
Old Jun 4, 2023 | 09:21 AM
FishOnOne's Avatar
FishOnOne
Originally Posted by Tam123
Hello,
Internet amplification.... There's been some lifter failures but believe they're a small percentage. Proceed as planned.
Old Jun 4, 2023 | 09:26 AM
Split rims's Avatar
Split rims
I don’t believe you’ll have any problems. I would however make sure that you thoroughly inspect the truck, including having the dealer check all fluids.
Good luck!
Old Jun 4, 2023 | 09:33 AM
pdumpbody's Avatar
pdumpbody
This engine hasn't been bad in the past. However, everything is presently being redefined by Ford. There is no telling what you're gonna get.
Old Jun 4, 2023 | 09:40 AM
Split rims's Avatar
Split rims
I sadly agree.
They pooched the fuel pump design on the 6.2 after 2016 when they bumped up the power.
You can only hope that it’s an improvement!
They hit a home run with the 2013 brake upgrade.
Old Jun 4, 2023 | 09:42 AM
GAZZILLA's Avatar
GAZZILLA
Please post links to these “problems online” and “YouTube engine failures”.
The only 7.3 failures I’ve heard of have been from big box trucks and fleet work trucks F-450 and larger on YouTube. I think they had high idle hours that caused oil starvation that lead to cam and lifter damage due to the variable displacement oil pump going into a lower oil pressure mode. None of the few failures I’ve heard of have been on F-250 & F-350’s.
I haven’t seen any thread on here about a FTE member having that problem.
Just don’t idle a 7.3 excessively and at least change the oil as recommended and everything will be fine.
I’ve had two 2022 7.3’s, I only put 5,3k on the first one and now 5,2k miles on the second one and no problems.
The 7.3 is solid, buy with confidence.
Old Jun 4, 2023 | 09:44 AM
HRTKD's Avatar
HRTKD
Hello,
For a regular travel trailer, an F-250 with the 7.3L gas engine is a good fit. People come here because they have problems (with their truck). So it looks like the sky is falling from all the posts of problems. Reality is quite different.
If I were to downsize my trailer or go to a slide-in camper, I would have no qualms about using the 7.3L engine.
Old Jun 4, 2023 | 09:53 AM
Tam123's Avatar
Tam123
2nd Gear
The 7.3 is solid, by with confidence.
it isn’t too hard to find online which has had me worried.
Old Jun 4, 2023 | 10:14 AM
GAZZILLA's Avatar
GAZZILLA
I’ve seen the first two videos. First one was of a 7.3 bought used that didn’t actually have a failure just high iron levels. The second was of a box truck. The third one is new to me. Well based on those three videos, if you have second thoughts about buying a 7.3 you should buy something else.
