Open/Closed loop transmission function
Old May 28, 2023 | 11:44 AM
Bignasty2's Avatar
Bignasty2
Hopefully one of you can point me the right direction. My freshly built 4r70w is having problems going into third and beyond while at the tuner. I have a kenne bell on the 5.0 in a 1994 F150 4x4. The transmission got a shift kit and the converter was brazed and tightened up a bit. I did drive the truck for a while without the supercharger, without issue. I have not ruled out the shift kit and converter as the mistake that led to my problems. I am wondering if anyone knows what/if the computer does things differently for open loop/closed loop operation when it comes to transmission function.
Also, what's a healthy O2 signal?
Thanks a bunch!
Old May 28, 2023 | 08:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Open loop/closed loop does not affect the transmission operation.
Old May 29, 2023 | 10:32 PM
Bignasty2's Avatar
Bignasty2
You're the man. Is the shift kit in this truck / electronically controlled transmissions a bad idea? I didn't think about it until after it was done. It was not a crazy shift kit. Transtar something. The tranny will be gone through again by the same guy. I'd like to be able to draw the proper conclusion as to the problem. Did he do a bad job? Did the converter guy do a bad job ( I got some glitter draining converter) ? Did I make a mistake letting him install a kit and cut open my converter? Ideally, I would like to stay with the kit. My hypothesis is the tighter converter in combination with the shift kit, starved something of pressure and burned something up. I do think I'm ditching the converter. I'll take all the input I can get. I don't need any "third times the charm" on my transmission. I still have a tune to be finalized.
THANKS!!!
Old May 30, 2023 | 11:09 AM
1Butcher's Avatar
1Butcher
Metal in the fluid is not a good idea but you have to understand that you have a truck that is almost 30 years old. Just because someone touches it, does not mean they screwed it up. Yes, it can happen, but things break and sometimes they break when you are working on it or minutes after you have. Just because you do an oil service does not mean the flat tire is the mechanics fault.
That said, if I had that transmission out, I would have gone through it. It's 30 years old. There has got to be some wear items that need to be changed out.
Old May 30, 2023 | 11:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by 1Butcher
Metal in the fluid is not a good idea….
What do you mean metal in the fluid “is not a good idea”? There was “glitter” when draining the converter. He wasn’t going to add metal to the transmission fluid.
Here is part of post #1 with highlighted words for you reread….
Originally Posted by Bignasty2
My freshly rebuilt 4r70w is having problems going into third and beyond while at the tuner. I have a kenne bell on the 5.0 in a 1994 F150 4x4. The transmission got a shift kit and the converter was brazed and tightened up a bit.
Old May 30, 2023 | 11:31 AM
1Butcher's Avatar
1Butcher
My mistake. I read the post right above about the converter.
Metal, glitter, whatever words are used, there should not be any in the fluid. Not certain why you thought that I was recommending that.
A good rebuilder would want to check things out. I would remove it out and see what went wrong.
Old May 30, 2023 | 11:44 AM
My4Fordtrucks
Because you used the phase that you did. It definitely need to go back to the shop that rebuilt the transmission to find out where that metal is coming from.
Old May 30, 2023 | 08:09 PM
Mark Kovalsky
No, it's not a bad idea. I can't tell from here if anyone did a bad job or not.
A tighter converter won't starve anything. A misinstalled shift kit can starve something, but once again, I can't tell if anything was done right or wrong.
A supercharger without the proper trans hardware and tuning will DESTROY a transmission. Getting the tuning right with the supercharger could very well be the cause of your failure.
Old May 31, 2023 | 12:04 PM
wwhite's Avatar
wwhite
Here is some info you may find interesting.
I have been tuning my stock 351w and have been having some intermittent hard/soft shifts depending on throttle position and load.
I only tuned fuel, nothing else.
I have put the stock tune back in due to other issues, and trans now shifts more smoothly all the time.
what I believe is going on is as you tune the engine, fuel tables etc. you will also need to tune the transmission tables as well, torque, rpm, 1-2,2-3, etc etc to match the engine power output.
im still learning, and I might be wrong
Old May 31, 2023 | 03:15 PM
Mark Kovalsky
You're right. That's how it has to be done to prevent destroying the trans while tuning.
Old May 31, 2023 | 09:10 PM
Bignasty2's Avatar
Bignasty2
You guys are awesome. I believe my tuner could be in a little on the deep side. It's really hard where I'm at to find someone to touch OBD1, so I am grateful. Is there some sort of resource I could point him to even if it's a paid thing? He may not have enough vehicle specific experience to be confident with the transmission portion. I'm not making crazy power by any means. I am putting out a good amount more torque and probably net more HP. I'm running rich with little timing on a little v8. If there was a guy that knew exactly what my transmission wanted tune-wise, I would pay for it and pay my guy to put it on there.
Old Jun 1, 2023 | 01:54 AM
wwhite's Avatar
wwhite
What EEC-IV computer do you have?
What tuning hardware and software are you using?
Knowing what hardware and software you have, we can then maybe point you to more information.
Old Jun 1, 2023 | 09:19 PM
Bignasty2's Avatar
Bignasty2
ECU is JAB1
I know it's quarterhorse and Binary editor rings a bell.
5.0 4r70w 4x4 3.55s 31" tires
MUCH APPRECIATED
luthoro
May 30, 2012 07:37 PM
breakfree
Jul 28, 2008 07:56 PM
BigBrownTruck
Dec 20, 1999 09:11 AM
