1977 Highboy engine question
Old May 25, 2023 | 02:34 PM
hollywoodtuck's Avatar
hollywoodtuck
4th Gear
I bought a 1977 F250 4x4 Ranger XLT
It came with what the guy said is a 390, definitely an FE (ribbed block) 68-352 cast into head.
the vin has H designated for the engine- mfg date is 12/76, according to the chart for decoding the vin it would be a 351m correct? It says the 390 did not come as an option from the factory on 4 wheel drive? Trying to figure out if the engine was swapped in at some point or what… motor mounts and everything look factory wouldn’t they be different?
this truck has A/C power disk brakes and steering along with the manual 4 speed and the newer style (no big knuckle) front end.
Old May 25, 2023 | 02:44 PM
85e150's Avatar
85e150
How many bolts holding the valve covers?
Does the intake manifold extend under the valve covers?
As OEM, no 390s in 4x4s.
Old May 25, 2023 | 03:16 PM
hollywoodtuck
4th Gear
Intake extends under the valve covers… ok guessing this engine was swapped in. 👍🏻 Thank you.
is the flywheel interchangeable by chance for FE and the 351/400m series engines?
The plan is to put my solid 2wd 77 body on it- it has a great running 351m with an auto.
id just have to find the right bell-housing. I’m going to restore the running gear first before moving anything around.
Old May 25, 2023 | 08:52 PM
440 sixpack's Avatar
440 sixpack
The FE is an upgrade, if it's in decent shape I'd leave it.
Old May 26, 2023 | 09:18 AM
mark a.'s Avatar
mark a.
No, flywheels will not interchange between the two.
morks
Car/truck Buying Advice
Aug 14, 2021 07:43 PM
BrnCreole
Aug 28, 2008 09:13 PM
5356f100
Feb 7, 2005 06:13 AM
blueblood1
Nov 4, 2003 09:17 PM
broncojim
May 10, 2000 08:10 PM
