Power Steering Fluid ??????
Old May 20, 2023 | 12:37 PM
ZachRitchie's Avatar
ZachRitchie
1997 F250 CCSB 7.3 E40D
i noticed i was a little low on power steering fluid so I just topped off with normal prestone power steering fluid but when i got home i researched it and people are saying ATF? so couple of questions what fluid should i be running in there? and is it bad that i mixed and is it worth doing a full flush? ive seen multiple different answers im just looking for the correct answer. thank you!
Old May 20, 2023 | 01:49 PM
Hit Man X's Avatar
Hit Man X
Would flush it fully, install a Magnefine inline filter and run whatever. I have PS in mine but I have read elsewhere ATF.
Probably if ATF use cheapo Dex/Merc.
Old May 20, 2023 | 05:20 PM
knottyrope's Avatar
knottyrope
ATF mercon V
Old May 21, 2023 | 07:12 AM
96SD's Avatar
96SD
Where is the best place to add the Magnefine filter?
Old May 21, 2023 | 12:40 PM
Hit Man X's Avatar
Hit Man X
Mine is zip tied to inner fender liner. Obviously on return side past OE cooler.
Might be a pic in my thread. Fluid still pretty clean.
Old May 21, 2023 | 12:44 PM
ZachRitchie
this might be a silly question but if i purchase the mercon v can i also use it in my tranny? figure if i can use it in my steering and tranny ill buy a big jug if not ill buy a small amount
Old May 21, 2023 | 08:41 PM
ZachRitchie
Originally Posted by knottyrope
ATF mercon V
will this Mercon v work in my transmission and my power steering?
Old May 22, 2023 | 06:29 AM
DanielT28's Avatar
DanielT28
Looks like it will
Old May 22, 2023 | 09:57 PM
ZachRitchie
Originally Posted by DanielT28
Looks like it will
thank you sir! just ordered up some mercon v for the trans and PS and transfer case it looks like thanks !
wicat3
15
Sep 24, 2012 06:20 PM
quisp-n-quake
23
Mar 13, 2008 01:29 PM
straightsixer
Feb 1, 2008 03:39 PM
94 1/2 stroker
Feb 1, 2006 10:07 PM
Bubba Shrimp
May 31, 2003 05:07 PM
