Power Steering fluid...
Old Oct 16, 2007 | 02:51 PM
quisp-n-quake's Avatar
quisp-n-quake
88 f150 5.0 4x4
Can I use tranny fluid inplace of the Power steering fluid?
-You used to be able to do this on older cars-60's & 70's models
Old Oct 16, 2007 | 02:55 PM
quicklook2's Avatar
quicklook2
i do not recommend it.
i have had very good luck using lucas power steering fluid.
Old Oct 16, 2007 | 03:04 PM
websthes's Avatar
websthes
I had a leaky power steering hose on my other truck. I put transmission fluid in there, even hydraulic fluid meant for the excavator at work. I don't think it hurt it any. In a pinch, better transmission fluid than nothing at all.
Old Oct 16, 2007 | 03:05 PM
Skandocious's Avatar
Skandocious
I do believe that Mercon ATF is the Ford spec for these power steering pumps... I use it in mine with no problems.
EDIT: I stand corrected. This is what my repair manual says:
Use Ford Premium Power Steering Fluid, or an equivalent power steering fluid that meets Ford specification ESW-M2C33-F.
Old Oct 16, 2007 | 03:21 PM
quicklook2's Avatar
quicklook2
and that is why i don't recommend it.
Old Oct 16, 2007 | 03:54 PM
wayneF250's Avatar
wayneF250
will that Lucas fluid stop that "whining" noise ........94 F250 5.8
Old Oct 16, 2007 | 04:01 PM
Skandocious
Probably not... The whining is just part of these Ford ps pumps. The Lucas might HELP but you aren't going to rid the truck of it...
Old Oct 16, 2007 | 04:10 PM
jas88's Avatar
jas88
I will say this - I have used Dexron ATF in every PS pump in every vehicle I have ever owned, and I have never had a pump failure. In my entire 30 years of vehicle ownership, I have only replaced one PS pump, and that was for a leaking case seal. Exactly what evils is the so-called PS fluid supposed to remedy if not the noise of a Ford pump?
Old Oct 16, 2007 | 04:19 PM
Skandocious
My thoughts exactly.
Old Oct 16, 2007 | 04:24 PM
nighthawk285's Avatar
nighthawk285
I do the same with the ATF, but I don't use the Dexron, I use the type F
Old Oct 16, 2007 | 04:36 PM
quicklook2's Avatar
quicklook2
lucas power steering fluid has helped the whine in over a half dozen fords i have owned.
if atf is not recommended by ford why use it?
Old Oct 17, 2007 | 12:05 AM
sconut1's Avatar
sconut1
Page 225 from 1988 F-Series owners guide:
Use only a fluid that meets Ford specification ESW-M2C33-F such as Motorcraft Type F Automatic Transmission and Power Steering Fluid or an equivilent type F fluid which displays a Ford registration number (2P- followed by six numerals)
Old Oct 17, 2007 | 12:11 AM
quicklook2's Avatar
quicklook2
different years require different fluids.
Old Oct 17, 2007 | 12:13 AM
sconut1's Avatar
sconut1
The original question is for a 1988 truck
Old Oct 17, 2007 | 07:32 AM
quisp-n-quake
PS Fluid..
Yep, Its just that I have a few Qts of dextron on the shelf, and the PS pump was a little low...I used it before on vehicles from the past...
I figured it would be cheaper to use what I allready have instead of going down to Autozone and by something else..
I noticed the whine this month, seems to come out every October for some reason,-weather change?..mabey, -Haunted?-yea, definately.
--What would happen anyway? -I mean if I use the trannyfluid? that stuff holds up to heat prettygood, and its like hydraulic fluid? whats the downfall??
'88 f150 5.0 4x4
