Removing 300 I6 engine - chain points
Old May 12, 2023 | 09:49 AM
NWPencrawler's Avatar
NWPencrawler
4wd Low
73 F250 2WD 300ci T-18 trans
Just found out I need to yank the engine and replace or rebuild it (crank is seized and will not turn by hand with plugs out, trans in neutral). To pull the engine, where are the best places on the block/engine to attach the cherry picker chains?
Thanks for the knowledge everyone!
Old May 12, 2023 | 03:32 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Welcome to FTE, if I had a picture I would share it, but I'm not one that usually documents what I'm doing... when I'm pulling a 6 out, I use a bolt in the front of the head on the dr side, and one of the exh/intake bolts on the rear of the engine on the pass side, I try to use one piece of chain for the engine, then hook that on the hoist hook with a bolt through to keep it from tilting/sliding front to rear, you may have to adjust that bolt in the chain to bring the nose up or down once you start lifting it.
Old May 12, 2023 | 05:27 PM
NWPencrawler
4wd Low
Removing I6 Engine - Chain points
Thanks very much, that is very helpful!
Old May 18, 2023 | 03:15 PM
hehateme36's Avatar
hehateme36
4th Gear
Just lifted my 300 out this past weekend with this setup. Everything went smoothly and held. A few different grade 8 bolt sizes for the different points but all common hardware. Also a 50 dollar spreader from Harbor Freight made this a lot smoother. Only 15-20 bucks more than the chain was going to cost me.
Old May 19, 2023 | 10:00 AM
NWPencrawler
4wd Low
300 chain points
Thanks hehateme36!!
That is perfect. I really appreciate the pics and advice on the load spreader from HF. I should be able to take care of this in the next few weekends. Cheers!
ftrk66
19
Apr 14, 2021 07:16 PM
yukgoon
16
Jul 8, 2008 08:22 PM
sevenL4
Mar 21, 2004 01:55 PM
bob-63-292
Oct 29, 2003 10:20 AM
58Model
Nov 15, 2000 11:43 AM
