engine removal
Old Oct 11, 2003 | 04:20 PM
bob-63-292's Avatar
bob-63-292
engine removal
I've got a 292 V8, 1963. Where do you hook up the engine hoist to the engine??? It's not real obvious to me (but I've never pulled an engine before).
Bob
Old Oct 11, 2003 | 08:15 PM
waterdog2's Avatar
waterdog2
Usually you can remove a bolt on each side of the intake manafold and put a longer bolt in place of the ones you remove and attach your chain or lifting device there.
Water Dog
Old Oct 11, 2003 | 09:29 PM
matt1morton's Avatar
matt1morton
If you have time weld up a piece of 1/4 inch steel that will bolt to the carb. mounts on the intake manifold and have a loop for a chain. Pull the engine and it is a cheap fix that if you make big enough can be used on all engines.
Old Oct 12, 2003 | 04:22 PM
Rosati's Avatar
Rosati
Easier than those, just wrap your chain around each exhaust manifold, run a grade 8 bolt thru it. Be sure to balance the engine (with or without trans) before picking up more then a few inches. Those old cast iron logs will hold the weiht with no problems.
Old Oct 13, 2003 | 09:40 AM
bob-63-292's Avatar
bob-63-292
I'll give 'er a try tonight then. Thanks!
Bob
Old Oct 27, 2003 | 11:07 AM
bob-63-292's Avatar
bob-63-292
Finally got it out! Outside of being unable to remove the distributor, was pretty straight forward. I bought a load leveler at HF and looped the chains around the exhaust manifold on each side.
I hear distributor removal is a common PROBLEM on these old engines so am leaving that effort to the machine shop.
Question: can these engines rest on the oil pan or should I build some support box to carry it down to the machine shop?
Bob
Old Oct 27, 2003 | 12:16 PM
Mike G's Avatar
Mike G
I have tossed one of my not-in-use spare tires in the bed (no rim of course) and dropped the engine into the hole with the pan in the middle of the tire. Need to secure it from the sides though as it will want to wobble around....
--Mike G
Old Oct 27, 2003 | 01:24 PM
Rosati's Avatar
Rosati
Told you it was easy.
Yes, the dizzy is hard to remove because of the dissimilar metals. You can remove it by heating the cast iron area around the dist and using a rubber mallet, tap the dizzy in several directions to free it up.
Old Oct 29, 2003 | 10:20 AM
bob-63-292's Avatar
bob-63-292
An old tire worked like a champ as a cradel. Have given the machine shop the task of extracting the distributor. Thanks for the advice, guys.
Bob
Luv2Cruise
Feb 1, 2019 05:20 PM
169521
Aug 4, 2015 12:53 AM
1950FordF1
May 6, 2015 07:25 PM
arvet19
Large Truck
Apr 10, 2015 02:55 PM
mgerdau
May 11, 2014 01:05 PM
