Strange Critter
Old May 1, 2023 | 07:55 PM
BamaBiggDaddy's Avatar
BamaBiggDaddy
Strange Critter
Just bought this ( I thought was a jewel) truck I was impressed with the fact it was a unibody. Cost me $500 and a sand blast cabinet but at least I can still use the cabinet. My first venture was to remove the front bumper, and I watched a you tube about removing the front clip I thought that's easy. Yep famous last words 8 bolts into I should have quit. The video said 3 bolts on left fender, 3 on right fender, and 2 frame mounts at radiator support. Well, many face full's of rust later no can do got the 6 fender bolts all located on rear part of fender two at top and one mounted to the inner panel. The 2 on frame had to cut off on bottom because even with the 11/16 on top held by ratchet and 3/4? under with 1/2 in impact no go. Tried to raise front clip wow no go. So am now in process of removing upper grill, center grill. Removed hood thought that might help release some pressure. Still a nope. Well about 5pm I'd had enough so cleaned up come in and googled radiator core support prices now I.m really depressed.
Old May 1, 2023 | 11:27 PM
Christmas's Avatar
Christmas
I feel ya! Sometimes it's better to leave good enough alone. These trucks tend to weld themself together over the years. I just ordered a new wiz bang product called Superzilla. I'll give it a go and see how it works.
Old May 1, 2023 | 11:50 PM
7BercMerc's Avatar
7BercMerc
The best way to get the front end apart is by taking the whole clip at once but you have to soak the bolts/nuts multiple times over a few days with you favorite penetrating oil... Not sure if you took off the two bolts that are accessed from inside the cab? Here is an image of mine.... Just takes two people to lift it off after you have all the wiring disconnected and the radiator out and the bumper off... Once it is off it is much easier to get the individual parts separated. Don't give up!
Old May 2, 2023 | 12:42 PM
BamaBiggDaddy
Ok missed the two inside cab, figures. My radiator core support is toast. Found a new one at NPD, Ocal Fl a 5 hour drive one way but $250 trk shipping! I like your tires they look familiar. I'll check the two bolts inside had to take a break my jack spilled it;s guts trying to lift the trk and had to go get a new one thank goodness for harbor freight.
Old May 2, 2023 | 01:05 PM
7BercMerc's Avatar
7BercMerc
Originally Posted by BamaBiggDaddy
..... to go get a new one thank goodness for harbor freight.
Yes! I picked up their low profile long reach Daytona jack in 2019... It has held up well.
Old May 3, 2023 | 01:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/64: The steering shaft goes directly into the gearbox. So once the steering wheel is removed, the steering column and the gearbox is removed as a one piece assembly.
Old May 8, 2023 | 07:06 PM
BamaBiggDaddy
Sounds like the spear of death my 65 Falcon had until upgraded to power steer
Old May 8, 2023 | 07:09 PM
BamaBiggDaddy
Need to throw out another question where are people finding the drag link for the 62 2wd Ihave the Moog number but seems no-one has it?
Old May 8, 2023 | 08:27 PM
Grampa69's Avatar
Grampa69
Hopefully nd or someone else will correct me on this. I have a 64 2wd and bought the last known link. It was from a Ford dealer. Moog has been contacted by a member to inquire about getting more made since there's a demand. They declined. I hope the link for 62 and 64 are different. Number Dummy should know.
Old May 9, 2023 | 01:23 PM
NumberDummy
C1TT-3304-M .. Drag Link / Obsolete
1961/64 F100/250 2WD with manual steering & 4WD // 1965 F100 4WD // 1965/66 F250 4WD w3,000 lbs. capacity front driving axle.
HAVEN FORD PARTS in Haven KS has 1 = 620-465-2252.
CARPENTER NOS PARTS in Concord NC has 1 = 800-476-9653.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965
Old May 16, 2023 | 03:52 PM
BamaBiggDaddy
Tried all the others they just HUH? Finally found one at Obsolete Ford Parts Company, it's in Nashville Ga. Phone 229-686-2470 or 229-686-5101, Also ObsoleteReliableParts.Com the old guy thatanswers is real nice and he will verify if he actually has part on hand. Got where he almost remembers me I.ve ordered enough from him plus he's conveniant I live in LA (lower Alabama) and him in Ga
konnor1
Nov 7, 2020 11:08 AM
michael a
1947 and Older Ford Trucks
52
Jan 16, 2016 10:39 PM
msauls
Feb 5, 2013 06:18 PM
tip49
Jul 23, 2009 01:47 PM
jared66
May 29, 2007 05:06 PM
