unbuilding
Old May 28, 2007 | 09:38 PM
jared66's Avatar
jared66
unbuilding
I would like to punch the engineer at ford who decided how the front fenders and grill where put together. I have spent a lot of time tearing down the front sheet metal without a whole lot of progress.
Old May 28, 2007 | 10:23 PM
daveengelson's Avatar
daveengelson
Found by removing the entire assembly as a unit it's much easier to disassemble once removed. Remove bumper, remove the bolts from the center support bracket; there is an opening at backside along the top of radiator support, using a socket you can remove the top bolts securing the center support, found using 1/4" socket set with small extention little easier, but 1/2" will work. Then remove bolts securing upper valance at the top of radiator support and fender, and bolts along permiter where the grille is secured to the fender and the entire assembly should come out. With any luck none of the speed, or cage nuts are rusted and spin on you. Once removed, any speed nuts that are rusted are easier to remove. From that point, suggest remove fenders and inner fenders (sheet metal) together. Obviously, the hood should have already been removed, make sure to mark hinge bolt location. Suggest take note of any hardware that needs to be replaced.
dave
Old May 29, 2007 | 05:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Take pictures and/or video. This will assist you when it all goes back together.
codafisler
Apr 23, 2012 10:18 PM
sgreen
21
Sep 25, 2011 03:28 PM
4EyedTurd
Jun 16, 2010 12:01 PM
sportscar
Car/truck Buying Advice
29
Mar 25, 2004 11:53 AM
pward76
Dec 21, 2002 11:42 AM
