Dash Lights
Old May 12, 2023 | 01:32 AM
Slick collector's Avatar
Slick collector
Dash Lights
I don’t know if this has already been covered, my dash lights quit working, when I pull the switch, there is now power coming from the fuse block, everything else works, fuses are new, grounds are good, blinker switch is new, all other fuses light up, it’s just the instrument fuse that has no power, is this a switch issue or is it in the fuse block?
Old May 12, 2023 | 04:20 PM
53deere's Avatar
53deere
Power to the fuse comes from the switch to the fuse and then to the lights. So if you have no power at the fuse I'd guess the dimmer in the switch is likely broken.
http://www.fordification.info/tech/i...sterwiring.jpg
Old May 12, 2023 | 08:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The rheostat inside the headlamp switch that dims/brightens the dash lamps has probably broken. This is a somewhat common occurrence as it is made of a ceramic material.
There is a button on the bottom of the switch, push the button and pull the headlamp switch ****/shaft from the switch. There is a small threaded nut that fits inside the headlamp bezel, it threads into the switch.
Remove the nut, the switch is now free of the dash. Remove the wiring. To reinstall the ****/shaft, just push it all the way in, there's no need to press the button.
Old May 12, 2023 | 09:45 PM
Slick collector
I was thinking the switch was bad, I just wanted to get opinions, I have a new one on order, I appreciate the replies.
Old May 16, 2023 | 04:17 PM
Slick collector
Problem solved:
after some tracing and test light work, I found a broke wire at the switch, switch is still good so, new connector, all lights work including cab light
flipklos
Nov 7, 2022 07:49 AM
wence5
Jun 13, 2022 04:55 PM
DesertZuki
May 15, 2015 11:03 PM
jordan101
Mar 22, 2011 11:46 AM
steedracer
Electrical Systems/Wiring
Nov 11, 2010 10:31 PM
