04 6.0
Old Apr 30, 2023 | 11:42 AM
Dumpbed's Avatar
Dumpbed
4wd Low
Hi Guys
I have a 2004 6.0
I have a problem with the waste gate I think
When i am driving it feels like the boost is not there when it acts up it will feel like the gate is opening when it needs boost. When it does it black puffs of smoke will come out of the exhaust
Old Apr 30, 2023 | 11:49 AM
bismic's Avatar
bismic
You might try to find the waste gate before you say you have an issue with it (ie you do not have one).
Old Apr 30, 2023 | 11:56 AM
Dumpbed's Avatar
Dumpbed
4wd Low
Hi bismic
Your telling me I do not have a waste gate on my 04
Could it be the soleniod
Old Apr 30, 2023 | 12:18 PM
bismic's Avatar
bismic
Yeah - sorry .... I couldn't resist.
The 6.0's have variable-vane technology. The solenoid operates the inlet guide vanes on the turbine side of the turbo. This happens in place of a waste gate.
You could have one of a half dozen issues. We really need to see a deep scan for codes. ALSO, we need to know where your ICP sensor is located (ie if your '04 has an '03 engine).
Old Apr 30, 2023 | 12:33 PM
Dumpbed's Avatar
Dumpbed
4wd Low
I also noticed that
1 it has no power
2 it revs higher before it will shift as well
Old Apr 30, 2023 | 12:37 PM
bismic's Avatar
bismic
ICP sensor behind the turbo?
You need a scan tool - one that does a deep scan for codes. With a scan tool, the first thing to do is to look at EBP_G, MAP, and Baro at KOEO.
ForScan full version or ForScan Lite are the way to go. TorquePro is good for Android devices.
Old Apr 30, 2023 | 12:44 PM
Dumpbed's Avatar
Dumpbed
4wd Low
Ok thank you
With the ICP sensor I thought if that was bad it will no t start
I will have to inquire on a scanner
Old Apr 30, 2023 | 01:03 PM
bismic's Avatar
bismic
I am asking about the ICP sensor location so that I can determine what year engine you have ..................
As I indicated above, the '04 trucks can have EITHER an '03 engine or an '04 engine.
The turbo is controlled differently depending on which engine is in it ...........
Old Apr 30, 2023 | 01:11 PM
Dumpbed's Avatar
Dumpbed
4wd Low
My appologies
I didnt read the other right
The engine is an 04
Old Apr 30, 2023 | 01:20 PM
bismic's Avatar
bismic
LMAO - we went through this in the engine model 3 years ago (laughing more at me than you)!
https://www.ford-trucks.com/forums/1...l#post19222060
So you should have an active EBP PID. Comparing EBP, MAP, and Baro at KOEO is the next step (along with codes).
From the old thread, the turbo does not sound very old, so maybe you can get this resolved fairly inexpensively!
Old Apr 30, 2023 | 01:44 PM
Dumpbed's Avatar
Dumpbed
4wd Low
Yes your right we did speak then
Issue was EGR cooler was bad
I do have paperwork on the turbo was changed at 30000
Old Apr 30, 2023 | 10:37 PM
lupuseven's Avatar
lupuseven
A "simple" check would be to inspect all the boots in the intercooler system for cracks. You may need to really squeeze and manipulate them to find it
Also check that the clamps are no broken. Happened to a buddy of mine, it just gave out and eventually fell off.
Old May 1, 2023 | 08:56 AM
Dumpbed's Avatar
Dumpbed
4wd Low
I am going to check all boots and take it from there
Old May 1, 2023 | 09:40 AM
bismic's Avatar
bismic
Also, check the MAP sensor hose - make sure it is not plugged up, not torn, and that the nipple on the intake manifold that it attaches to is not plugged up.
Old May 1, 2023 | 09:51 AM
Dumpbed's Avatar
Dumpbed
4wd Low
I will do that thank you
Bigchris89
Mar 24, 2020 02:40 PM
twesley
Oct 22, 2013 12:08 PM
davisdanny32
Jan 19, 2011 03:54 PM
Packard V8
Sep 16, 2009 05:29 PM
