04 6.0 No Boost Code2262
Old Jan 18, 2011 | 02:51 PM
davisdanny32's Avatar
davisdanny32
I got a 04 F250 6.0 Just did a EGR Delete, Replaced Turbo(Old one was Bad) New FICM, All the Hoses r tight No leaks,Map Sensor and Hose R good, VGT Solenoid Replaced, No Exhaust Leaks No INtake Leaks, U can hear the Turbo Spin Real Good But NO Power and Code2262 Could there be something im overlooking These Turbos R not hard to take apart and replace, Veins Worked Great Brand New Unison Ring...
Old Jan 18, 2011 | 05:52 PM
npccpartsman's Avatar
npccpartsman
check the code here: 2005 Update Page 10 Diagnostic Codes P2199 thru U0306
Old Jan 18, 2011 | 06:43 PM
cheezit's Avatar
cheezit
check the map hose and make sure it hooked up correctly
Old Jan 18, 2011 | 07:06 PM
davisdanny32
yep i checked that and cleaned the Nipple that goes into the intake everything is clear
Old Jan 18, 2011 | 07:07 PM
davisdanny32
could the intercooler cause this? if it were cracked somwhere
Old Jan 18, 2011 | 07:08 PM
cheezit's Avatar
cheezit
yes. look at both sides and see if you can see a big o-ring hanging out betweeb the tank and the core.
Old Jan 18, 2011 | 07:22 PM
davisdanny32
This Truck has been smacked in the front before and it doesnt look like the right intercooler but ill check for the o-rings they had a econoline straight hose on the turbo and i had to get a elbow hose to go back on it. so who knows where the intercooler came from but this truck did run good at one time. it only has about 53k miles on it
Old Jan 19, 2011 | 03:54 PM
davisdanny32
Well Cheezit U R tha Man!! After close inspection i found the Intercooler was blown I had to look real good but finally found it Thanks Now on to the 7.3 that wont crank
Chipper j
Apr 12, 2016 12:28 PM
tcjhkbjt
Sep 30, 2013 07:15 AM
SubZero
Feb 14, 2012 07:20 PM
teague350
Sep 30, 2011 04:49 PM
jeklhyde
Apr 12, 2010 10:33 PM
