Dry axle shaft ?
Old Apr 21, 2023 | 12:04 PM
tbruz's Avatar
tbruz
Dry axle shaft ?
1975 F250 Highboy with FE360,C6 trans and Dana 60 rear end
Recently I had to replace brakes all around and all associated components; i.e. axle seals, hardware, shoes, wheel cylinders, wheel seals, repacked wheel bearings, etc.
I've driven about 400- 500 miles since the brake service was completed.
As part of the rear axle brake service, I topped off the rear end lube level until it dripped out of the fill hole.
I had been second guessing myself regarding the axle nut torque I used so I decided to pull rear axles today just to calm my brain and recheck the torque.
All was good; torque-wise but....while the passenger side axle was nicely lubricated along its entire length, the drivers side axle was bone dry.
Does this seem correct?
Thanks in advance.
Tbruz
Old Apr 22, 2023 | 05:34 PM
tbear853's Avatar
tbear853
Sure .... if the truck was not dead level. If on a dead level for a period of time, they both my be dry.
Old Apr 23, 2023 | 07:38 AM
Ozzie H.'s Avatar
Ozzie H.
The 1976 Ford shop manual says (page 11-14-1) The wheel bearings are packed with wheel bearing lubricant (C1AZ-19590-B) to provide initial lubrication until axle lubricant flows into the wheel hubs and bearings during vehicle operation.
Old Apr 23, 2023 | 09:52 AM
tbruz's Avatar
tbruz
Ozzie H- Wheel bearing were re-packed at brake service. DS side axle is currently dry after 400-500 miles.
tbear853- garage floor is dead level, I even went as far as jacking up the passenger side for a couple hours(lube flow side) to see if I could force some lube into the dry side via gravity. No joy on that either.
Lube fill level is correct to slight higher than correct as I've added some lube over the past few days to see if I could force the flow.
Thanks
Tbruz
Old Apr 23, 2023 | 07:14 PM
tbear853's Avatar
tbear853
You have a 3/4 ton truck with free floating hubs, the axles just slide in / out after outer end bolts are removed. The wheel bearings are packed aren't they? The axles enter the rear at the same level directly opposite each other. , if one is wet and one is dry, then the truck has a low rear tire tilting the axle housing or the floor is not level. As you drive, one will often be submerged due to roadway superelevation, curves, side hill driving. You said the bearings were packed. There are no seals for the axle shafts, they enter the differential directly opposite each other, one is no higher than the other. Even if the axle shaft is dry, there can still be lube oil in the much larger axle housing tube. Think of the rear axle housing as a bubble level.
(9) What is a full floating axle, and what are the advantages? - Quora
Old May 8, 2023 | 04:04 PM
uzikaduzi's Avatar
uzikaduzi
i thought you weren't supposed to pack the bearings in a rear dana 60... just wet them with gear oil as they are oiled through the axle tube?
Old May 8, 2023 | 04:23 PM
moose4x4's Avatar
moose4x4
FTE Remembers
I always jack up one side of the axle so the fill hole is up from where it should be. Then fill till it runs out of the fill hole( thus overfilling it). That way it will be sure and get some lube out to the wheel bearings, then after driving for several days you could remove fill plug and let some out if you are concerned about overfilling. I don't!
Old May 8, 2023 | 06:07 PM
john jamieson's Avatar
john jamieson
Is the axle bent in some way?
Old May 8, 2023 | 08:27 PM
tbruz's Avatar
tbruz
Axle is not bent. This truck lived a very easy life.
I ended up pulling out the DS axle and jacking up the passenger side until oil flowed out the DS axle tube.
Having satisfied myself that there was no blockage, I re-installed the DS axle and called it "good-to-go".
I've since treated the D60 rear end(and D44 front end) to a complete lube change with Lube Locker gaskets in case I have to go in there again.
Thanks
Tbruz
Old May 9, 2023 | 11:27 AM
uzikaduzi's Avatar
uzikaduzi
take this all with a huge grain of salt... i'm not an engineer or even a mechanic. I know plenty of both couldn't pour **** out of a boot with instructions on the bottom. i have family members in both categories and i remember a conversation they had about butting too much oil in an engine and that causing additional aeration of the oil (which decreases it's lubricity) and a reduction of the cooling capacity of the oil. I don't know if this is even true let alone correlates to differentials... honestly I didn't know oil contributed to any significance to cooling in a water cooled motor, but apparently it does? if that's all true, it seems to me it might take a bigger toll on a differential?
BlueWhiteFord
Jun 9, 2020 01:49 AM
BlueWhiteFord
Apr 17, 2020 08:24 PM
Bootlegger's Deluxe
Jun 17, 2018 11:45 PM
erniephillips
1983 - 2012 Ranger & B-Series
Jan 11, 2008 08:45 PM
03 van
Feb 1, 2004 04:28 PM
