Rear Diff Identification
Old May 9, 2023 | 10:02 AM
NoakeaBean's Avatar
NoakeaBean
Can someone tell me what kind of rear differential I have? Is it open or possy? Thank you!
Old May 9, 2023 | 11:47 AM
uzikaduzi's Avatar
uzikaduzi
its a ford 9" carrier, can you get a pic of the bolts on the other side holding the ring gear? I think that's an open diff... if the bolts are not counter sunk, i'm more confident it's an open diff, if they are are counter sunk, it could be a trac loc?
Old May 9, 2023 | 11:49 AM
NoakeaBean's Avatar
NoakeaBean
What is trackloc?
Old May 9, 2023 | 11:56 AM
uzikaduzi's Avatar
uzikaduzi
pretty sure that's a trac lok... trac lok is a specific limited slip diff they are a common OEM LSD and should be the option on a lot of f100/150's of the time
Old May 9, 2023 | 11:57 AM
NoakeaBean's Avatar
NoakeaBean
Originally Posted by uzikaduzi
pretty sure that's a trac lok... trac loc is a specific limited slip diff from spicer (dana) they are a common OEM LSD and should be the option on a lot of f100/150's of the time
okay. So I pretty much have a LSD? And what does that all mean? Sorry, I’m kinda new to differential stuff.
Old May 9, 2023 | 12:06 PM
uzikaduzi's Avatar
uzikaduzi
its one of the most basic types of LSD's that functions with clutches... the type you have to add friction modifier to the gear oil in the diff.
I mentioned spicer (dana) the manufacturer, but i edited that out... i know spicer makes them, but as i think about it, i've seen other manufacturers use the same name for their clutch style LSD's. not sure if dana made the ones ford put in their trucks or not.
this is 1 step better than an open diff and fills the need for the vast majority of people who want/need a LSD. if you were off-roading heavily or drag racing, it would likely be barely adequate with much better options available.
Old May 9, 2023 | 12:08 PM
NoakeaBean's Avatar
NoakeaBean
thanks for the help. So when I go to add gear oil, I need to buy some friction modifier too?
Old May 9, 2023 | 12:12 PM
uzikaduzi's Avatar
uzikaduzi
yeah, i believe it's 1 oz per quart, if you add it and your diff is chattery, you can add a little more, but go easy on that.
Amazon Amazon
Old May 9, 2023 | 12:14 PM
uzikaduzi's Avatar
uzikaduzi
the forum pasted the link i shared odd... the amazon link above is for the motorcraft friction modifier
Old May 9, 2023 | 12:17 PM
NoakeaBean's Avatar
NoakeaBean
Awesome thanks! I’ll just pick some up at autozone or Napa when I get my new gasket and crush washers
gdmafia
Dec 12, 2022 09:30 PM
Buckeye71
Jul 17, 2021 08:40 PM
ladewigm
Jan 30, 2003 01:35 AM
