Hard cold start help
Old Apr 12, 2023 | 10:53 AM
Bquinley's Avatar
Bquinley
6th Gear
Hey guys, I’ve got an 05 6.0 with 266k, egr delete and hpop update are only mods. Recently if it’s below 75f outside the truck is hard to start cold, if it’s below 65f truck will not start cold. Now once started and driving if I just let off the gas it will sometimes just stall. Cranks right back up everytime so far but I don’t feel comfortable driving it because my area is hilly and I lose brakes and steering momentarily. I thought it was an stc fitting going out in the hpop so I’ve currently got that opened up only to find it’s been replaced already. Should I go to cam position sensor next? I thought maybe a wire short but I can recreate the stall in my driveway repetitively by revving and just letting go of the gas pedal. I do not have a tuner or scanner unfortunately but I have zero check engine light
Old Apr 12, 2023 | 03:54 PM
bismic's Avatar
bismic
Got plans to get a good scan tool?
Old Apr 13, 2023 | 10:39 AM
Jokester00's Avatar
Jokester00
THIS! The only way to know what the truck is doing or TRYING to do is to watch the data in real-time!
And make sure you fix that exhaust leak while you're in there
-jokester
Old Apr 13, 2023 | 10:20 PM
LindenBruce's Avatar
LindenBruce
My first thought might be dummy plugs and stand pipes in the oil rails. But, you really need to find a way to monitor what is happening. Do you have a laptop or tablet? If so all you need is the appropriate cable and a relatively inexpensive app and you can do a lot of diagnostics. Hell, even a blue tooth OBD2 adapter and an app on your cell phone will help. Yeah, that exhaust leak is gnarly and won't help matters. B.
Old Apr 14, 2023 | 01:18 AM
bismic's Avatar
bismic
ForScan Lite on a smartphone (with a $45 OBDII adapter) is very powerful and is a thorough code reader. Even Torque Pro is very good.
Funny how some people seem to act when it is suggested to get a good scan tool. They either think that it is too expensive, or that not having one is a permanent (unachievable) condition for some reason.
Old May 6, 2023 | 02:40 PM
Bquinley's Avatar
Bquinley
6th Gear
-jokester
I have ordered a new Bluetooth scanner and have torque pro on tablet for monitoring now and can use forscan on laptop if needed. Everything is put back together for now until I can buy downpipes and whatever else my scanner leads me to. What exactly do I need to be looking for? What signs point to dummy plugs? Watching ficm voltage is pretty straightforward but I'm not sure on ipr and icp what I'm looking for
Old May 6, 2023 | 03:19 PM
bismic's Avatar
bismic
Checking for codes first!
Then, watch the following parameters when it is taking an extended cranking eriod to start:
Cam/Crank Sync
FICM Sync
FICM MPower
FICM LPower
FICM VPower
ICP sensor volts
ICP pressure
ICP desired
IPR % duty cycle.
Old May 6, 2023 | 03:20 PM
bismic's Avatar
bismic
As far as dummy plugs and standpipes go, you might need those updated IF you still have the old style installed in the oil rails. The only way you can know that is to remove the valve covers and see what type and size of bit/tool will be needed to remove them.
Old May 6, 2023 | 07:31 PM
Bquinley's Avatar
Bquinley
6th Gear
Cam/Crank Sync
FICM Sync
FICM MPower
FICM LPower
FICM VPower
ICP sensor volts
ICP pressure
ICP desired
IPR % duty cycle.
My Bluetooth scanner will be here tomorrow and I will post results, thanks!!
Old May 7, 2023 | 04:02 PM
Bquinley's Avatar
Bquinley
6th Gear
Cam/Crank Sync
FICM Sync
FICM MPower
FICM LPower
FICM VPower
ICP sensor volts
ICP pressure
ICP desired
IPR % duty cycle.
these are my current fault codes looks like issue could be cam position wire ?
Old May 7, 2023 | 04:47 PM
LindenBruce
Ok, you got codes. Cool. Keep that list written down somewhere and now clear them all. You want to see if they return in a relatively short time period. The glow plug faults could contribute to slightly longer crank to start times, more so in cold weather. Diesels are compression-ignition engines so they need heat to fire the fuel. Glow plugs aid in that process.
It's very possible you have a chaffed/shorted/broken wire in your cam position sensor wiring. Give the harness a VERY good visual/tactile inspection for anything obviously wrong.
Now, did you get any data yet that Bismic listed for you to check? If not, can you get that and post it up? B.
Old May 7, 2023 | 04:56 PM
bismic's Avatar
bismic
You should troubleshoot your glow plug system. Either all glow plugs are bad or a GPCM is bad.
Definitely would be good to see the requested data when all it will do is crank, but I would focus on the glow plugs first!
Old May 10, 2023 | 11:33 AM
Jokester00's Avatar
Jokester00
Here's a link i've used in the past to troubleshoot the glow plug system.
6.0L Power Stroke Glow Plug System Troubleshooting Guide (powerstrokehub.com)
-jokester
Old May 12, 2023 | 10:49 PM
Bquinley's Avatar
Bquinley
6th Gear
Okay so Bluetooth adapter I got sucks and doesn't stay connected so no live data for now. I. Going to order a much better one next week. Anyways, I decided to go ahead and check out the cps and here's what I found. The two wires are completely bare and were twisted around each other so definitely causing issues and the actual cps was really bent I'm not sure if it's supposed to be like that but I'm replacing anyhow. Removal of the cps was pretty easy once I removed battery tray and one wire bundle in the way
rglowacki
Jun 5, 2019 06:09 PM
joe blow
May 1, 2014 10:10 PM
Restlesswildman
Dec 8, 2013 11:13 PM
97_Stroke
Mar 2, 2013 09:50 PM
87BRIIXLT
Bronco II
Mar 10, 2011 08:32 PM
