Bronco II Ford Bronco II
Will not start in the cold
Old Dec 12, 2010 | 08:00 AM
87BRIIXLT's Avatar
87BRIIXLT
I have a 87 Bronco 2 XLT and i am having problems witbh it starting in the cold. hell it wont start period in cold. i live in va and it is just starting to get cold. this is a problem. i have a few people tell me its my EGR valve sensor that is giving me problems, and that is why it is not starting.
so here is the run down. i go out in a cold day/night/morning and i go to start engine. it turns over. it will turn over all day. but it will not catch. this is happened a few times. and again it only happens when it is cold. please help guys
Old Dec 12, 2010 | 11:27 PM
mrshorty's Avatar
mrshorty
I would start with a couple of basics: when it won't start does it have fuel? Is the fuel rail pressure in spec (~40 psi)? Does it have spark?
Old Dec 19, 2010 | 01:55 PM
87BRIIXLT's Avatar
87BRIIXLT
i found it after i did some reaserch. it was the maps sensor thank you tho
Old Dec 19, 2010 | 11:51 PM
mrshorty's Avatar
mrshorty
Since diagnosis is often 90% of the battle, would you care to elaborate on how you determined the MAP was the cause of the no start?
Old Dec 20, 2010 | 09:12 AM
tommyleea's Avatar
tommyleea
Glad you fixed it. I was thinking more like a coolant temp sensor. I guess you never know!
Old Feb 28, 2011 | 09:00 PM
The_SnowMan710's Avatar
The_SnowMan710
my dad's has been having the same issue. no fuel pressure, so he figured the fuel pump...welp, put the 2nd one in last night and today it left me stranded at work. this BII is hit and miss though, this morning it cracked off and then tonight, like i said, nothing. even though it is hit and miss with this problem, when it does act up it is cold outside. would it be the MAP on this one too? i would have never guessed the MAP in a million years, personally...how does that keep my engine from firing? i'm educated as a diesel tech so some of these gas fuel systems kinda boggle my mind...
any thoughts?
Old Mar 10, 2011 | 08:32 PM
87BRIIXLT's Avatar
87BRIIXLT
this is late i know but i figured out because i found out the is the map sensor was bad tht it for some reason wouldnt let the truck start. and when i checked it it had gunk in the sensor, so it was forsure bad. once i repaced it had no problems.
WoodenUnion
Dec 9, 2016 11:31 PM
DinoB
Jul 3, 2016 07:24 AM
PeaceRestored
2009 - 2014 F150
Feb 15, 2016 08:44 PM
acf6
Nov 27, 2015 06:50 AM
canoechris
Bronco II
Apr 2, 2014 10:39 PM
