Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1959 F700 Decode
Old Mar 19, 2023 | 10:59 PM
Newyork6984's Avatar
Newyork6984
2nd Gear
1959 F700 Decode
I just want to say Hello and thank you in advance for any and all help. I'm in need of any info I can find on this serial plate and if their are any other spots on the truck I could look for more stamping to decode possibly. The data plate posted is all I could find and was in the glove box, This truck and mechanisms are incredibly wild underneath and I will start a thread soon on the restoration but for now any info on the decode would be awesome! Thank you again for anyone's help..
Old Mar 20, 2023 | 05:07 PM
85e150's Avatar
85e150
Welcome to FTE! I am giving you your own thread for this truck. Lots easier to get information specific to the truck that way.
F70 = F700, 21,000 lbs GVWR
C = 292 2V MD Ford Y-block gas V8, 158 certified net HP @ 4000 RPM
9 = 1959 model year
U = Louisville Assembly Plant
27122 = Serial number
175 = 175 inch wheelbase
X = I do not have complete info on paint codes and this one doesn't show in what I do have.
F70C = Not shown. Model codes are one letter and three numbers, like F700 or F701 etc. If a typo and it should be F700, then it's F700, 21,000 lbs GVWR
28 D = 28th day of 4th month, so April 28th 1959 production.
H = Clark 250V OR New Process 540 five speed direct transmission
12 = 7.20 rear axle ratio. No other axle info, but the axle should have info above the pinion and on the housing, driver side front.
No front axle code, possibly simply not provided for that model year.
21000 = 21,000 lbs GVWR
158 4000 = 158 certified net HP @ 4000 RPM
No DSO shown.
Let me know if something doesn't line up.
Partial '59 shop manual with some engine specs:
https://www.forelpublishing.com/demo/Demo20059.pdf
Old Mar 20, 2023 | 07:47 PM
Newyork6984
2nd Gear
Thank you sir for your help all help is greatly appreciative. It's definitely going to be a fun journey with this one. After quite a bit of research I did find the color code looks to be goldenrod yellow which on the doors up close you can see it under the hand painted Powers American logo. I will be investigating the truck a lot more now since the brakes are functioning and I can move it around.
Anything or anywhere else can I look for numbers to decode on the truck or is that it for the most? Thanks.
Old Mar 20, 2023 | 07:50 PM
85e150's Avatar
85e150
That's pretty much it.
The transmission will have numbers or identifying marks on it to see if it is Clark or NP, and the axle will have a tag on it or numbers stamped showing the manufacturer, model etc.
You shouldn't have widowmaker wheels but post a picture if you want.
If it runs and you've been through the brakes and they work, you are well on your way......
Big Kaz72
Large Truck
Dec 7, 2022 07:20 PM
5D Ranch
Large Truck
Jul 3, 2022 02:17 AM
phil3452
May 4, 2022 11:22 PM
Cycleguy803
Large Truck
Apr 16, 2022 09:22 PM
KK560
Large Truck
Mar 6, 2022 08:54 PM
