1958 T700 VIN Decode
T74 = '58/'59 T700, "28M rr. bogie"
N = 302 4V Lincoln derived Y-block, 172 net HP @ 3600 RPM
8 = 1958 model year
U = Louisville Truck Plant
21953 = Serial number
156 = 156 inch wheelbase
S = I don't have the codes for '58 and can't find anything that looks correct.
20B = February 20th 1958 build date
K = Clark model 265V five speed direct transmission
17 = 28,000 lbs capacity rear axles, 7.79 ratio
No front axle code--this truck is a special order, so the front axle may have been a special order, or may have been the standard axle and not listed. There will be numbers cast into the front axle.
32000 = 32,000 lbs GVWR
172 3600 = 172 Certified Net HP @ 3600 RPM
420077
42 = Fargo District Sales Office
0077 = Special Order Number.
To decode everything and find parts etc, you need the Master Parts Catalog for your year truck. You can find paper copies on line, and there are CDs available with much the same info. I use the free on line Demo versions and the search function here and on the internet to find stuff that's missing out of those abbreviated demo versions. There are also shop manual demos on line too.
Partial MPC
https://www.forelpublishing.com/demo/Demo20080.pdf
Demo shop manual
https://www.forelpublishing.com/demo/Demo20058.pdf
The full deal on CD:
https://www.hipoparts.com/1957-63-fo...ts-catalog-cd/
Does this truck run?
You are beyond a VIN decode so I'll give you your own thread.
8 = 1958 model year
420077
Partial MPC
Demo shop manual
