1958 ford f600 axle code help
Old May 4, 2022 | 09:46 PM
phil3452's Avatar
phil3452
jist got this truck home today and have searched for hours on what axle code 53 is. any help???
Old May 4, 2022 | 11:22 PM
85e150's Avatar
85e150
Welcome to FTE! Usually these go up in the Large Truck Forum. For now:
F60 = F600, 17,000 lbs GVWR
D = 292 4V HD Y-block V8, 158 net HP @ 3600 RPM. ( note this conflicts the HP number on the tag--the 272 4V HD for '57-'58 was rated at 149, looks like a typo...)
8 = Model year 1958
E = Mahwah Assembly Plant
39493 = Serial Number
172 = 172 inch wheelbase
R = Red
05 F = Looks like June 5, 1958 build date.
F = Warner model T98A four speed transmission, synchro in 2-3-4.
53 = Two speed rear axle, almost certainly Eaton, 15,000 lbs capacity, 5.83/8.11 ratios. (ratio is stamped above pinion, other info on the carrier and the driver side front of the housing)
No front axle, either obscured by the rivet or not there. Probably no more than 5,000 lb capacity,
17000 = 17,000 lbs GVWR
1494 3600 = looks like a typo for certified Net HP, see above
DSO not shown. Maybe another typo, they had to send it somewhere to sell it!
We had a red '58 292 4v, 4 speed/2 speed axle on the farm, so it's like old home week!
Beware widowmaker wheels, and go through your brakes but beware there are no new drums to be had.
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
M998
Mar 18, 2005 09:16 PM
cannonfodder
Jul 19, 2004 09:50 AM
Marvin882
Jan 22, 2004 05:08 PM
Steve_Uzi
Jun 18, 2001 04:57 AM
