Preventive maint work
Old Mar 22, 2023 | 04:43 PM
BryanStein's Avatar
BryanStein
Originally Posted by CGriff71
What do you mean by soak? I have changed my sensors and put a new oil temp and new water temp sensors in. Still same deltas. I have flushed a coupled times but this time coolant looks mud brown.
Let it sit, turned off,
But, sounds like you've verified your temps already by changing the sensors.
Old Mar 22, 2023 | 04:49 PM
BryanStein's Avatar
BryanStein
As far as injectors I was really thinking 155/30 but the only reason I was thinking about injectors and studs was because going to be in there anyway.
Doing oil coolers and injectors does not entail removing heads. Removing the heads and doing studs and HGs involves a cab lift of motor out the front. That's much more involved that simply pulling the valve covers for injectors and pulling the intake for the oil cooler. Three different jobs, really. The only thing they have in common is you pull the turbo and intake on oil cooler and HGs. Not on injectors.
I know people have done Studs one at a time without doing HGs. Maybe there's nothing wrong with that, but I just couldn't do it on a good running engine.
jk_hooper
Jul 1, 2014 11:11 PM
maxtruck00
Jun 2, 2014 12:18 PM
Jlrossini
Mar 20, 2014 09:40 AM
EddieEX10
Jan 6, 2013 04:39 PM
Banshee426
45
Jun 4, 2010 12:53 PM
