Head studs and gaskets?
Old Jun 1, 2014 | 04:45 PM
maxtruck00's Avatar
maxtruck00
So this is a continuation of me plugging my own oil cooler during a coolant flush. -note to self we will NOT be flushing the other 6.0l truck .
So with the oil cooler being next i figured id pull the cab to make life easy. (i hear to R&R the cab is two hours.), and install a Garrett Powermax turbo, and replace the up-pipes.
I'm trying to determine if it makes sense to replace the head gaskets and install head studs? They are not leaking, but since i'm not familiar with the 6.0; i don't know if i'm supposed to be worried about it..
I know the head gaskets were replaced about 50k miles ago by the previous owner, if that makes a difference?
When one replaces head gaskets i would think it makes sense to have the heads rebuilt?
Or should i leave the cab on, and just bang out the oil cooler and turbo stuff?
i'm looking for been there done that experiences.
Old Jun 1, 2014 | 04:55 PM
Money-Pit's Avatar
Money-Pit
I'd just do the turbo and oil cooler.
My experience is...if it ain't broke, don't fix it.
Old Jun 1, 2014 | 05:12 PM
73fan's Avatar
73fan
Considering your gaskets are only 50K old, I would recommend only doing your oil cooler and turbo. Might not hurt to throw out the EGR cooler at this point ... (Maybe you already did?)
Sent from Nexus 4. IB AutoGroup
Old Jun 1, 2014 | 05:32 PM
mustang_309's Avatar
mustang_309
Im in the same group as these fine fellows, if there is not a problem don't mess with it and I wouldn't pull the cab to do your oil cooler.
Old Jun 1, 2014 | 06:00 PM
jswartz84's Avatar
jswartz84
Sounds unanimous.
Old Jun 1, 2014 | 07:22 PM
cheezit's Avatar
cheezit
It takes 10 min to pull a turbo, oil cooler, egr cooler and up pipes is a 5 hour job cab on. If its your first run at it it will take alot longer. Pulling a cab for that is a waste. It will take you longer on the first run at that as well.
Old Jun 1, 2014 | 07:42 PM
John Irwin's Avatar
John Irwin
Cheezit is the only man on earth that can pull the turbo in 10 minutes, it takes the rest of us an hour.
I agree with the rest, I wouldn't change the gaskets, once they are torqued properly they don't experience much trouble. My 06 made it through months of a blown egr cooler, lots of towing and other stuff for 230,000 miles and never popped a gasket - they were torquing them properly by that year. And if you're not doing the head gaskets, I sure wouldn't pull the cab.
Old Jun 1, 2014 | 08:22 PM
steelhead2's Avatar
steelhead2
Ha, gotchya beat. I pulled my turbo in 8min in a fit of rage.
Old Jun 1, 2014 | 09:07 PM
cheezit's Avatar
cheezit
Now that was funny and I don't care who you are.
Old Jun 1, 2014 | 09:10 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
ROTF, I have those from time to time... Things tend to come loose or apart a little faster...
Old Jun 1, 2014 | 09:26 PM
Restlesswildman's Avatar
Restlesswildman
Video or t didn't happen!
Old Jun 1, 2014 | 10:00 PM
maxtruck00's Avatar
maxtruck00
Maybe the factory head bolts/gaskets aren't as big of a problem as i thought. I guess ill wait on the head gaskets/studs...
Is there a good way to monitor the gaskets? -before i bought the truck, I took it to a diesel shop and they gave me a print out, showing me all the cylinders held the same pressure. I don't think my AE has that capability..
Also who is making up pipes for these 6.0's?
I googled and found only 2 companies, and a third MBRP i could pre order from.
Old Jun 1, 2014 | 10:31 PM
Money-Pit's Avatar
Money-Pit
If the head gaskets were replaced 50k miles ago, it's possible you already have studs.
Old Jun 2, 2014 | 12:18 PM
73fan's Avatar
73fan
At least an hour! I've had a lot of sweat getting mine out! Don't know why, but it was just STUCK! 😤
xsr99
Feb 10, 2014 08:02 PM
EddieEX10
Jan 6, 2013 04:39 PM
Irish816
Jun 2, 2012 09:45 AM
ford-e-tude
Sep 18, 2009 01:29 AM
Prototype 305
Aug 19, 2009 05:03 PM
