Oil Slinger
Old Mar 14, 2023 | 09:59 PM
mauser3's Avatar
mauser3
4wd Low
Oil Slinger
Truck is a 99.5 250 super duty 4x4. Needed to replace e-brakes so while im there its getting new bearings. Was careful taking the seal off not to break the slinger but there wasn't one. This is on the drivers side and has never been pulled apart since new. Called two different dealerships and they said i didnt have one for my truck ( gave them my vin). Iv ordered timken bearings so should i get the slinger and put it on anyway
Old Mar 14, 2023 | 10:10 PM
hobohilton's Avatar
hobohilton
Did you have a failure due to lack of lubrication ?
Old Mar 14, 2023 | 10:28 PM
mauser3's Avatar
mauser3
4wd Low
No, there were no leaks or failures. truck sat for a long time so i decided to change them
Old Mar 14, 2023 | 10:29 PM
Kwikkordead's Avatar
Kwikkordead
I thought they had a press in seal that was kind of self contained. At least it was like that on my 550 with Dana 135 axle.
Old Mar 15, 2023 | 01:27 AM
FinnishStroker's Avatar
FinnishStroker
5.9 Cummins is known as The Oil Slinger.
Old Mar 15, 2023 | 04:52 AM
Walleye Hunter's Avatar
Walleye Hunter
There are two seals, IIRC, one inner and one outer and there is also an oil slinger. IIRC, it is a steel ring and something makes me think it has teeth on the outer edge of it. I looked and didn't find any pictures of it in my files.
Edit: One seal on the inside and an O-ring on the axle on the outside.
Old Mar 15, 2023 | 06:13 AM
Dan V's Avatar
Dan V
I put new backing plates on a SRW 10.5....the seals are one piece, no additional slinger. Must be why they are like $30/ea.
Old Mar 15, 2023 | 07:46 AM
RA101725's Avatar
RA101725
Banned
I could have sworn it showed one on the 10.5" axle looking at the shop manual. I wondered if there was one missing as well off my Dana 80 when I did a hub job but apparently those really didn't come with one. Maybe it was revised at some point on the 10.5".
Old Mar 15, 2023 | 08:20 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
FYI...
No mention of an oil slinger in the subsection 205-02C: Wheels Hubs and Bearings - Full Floating Axle - Dana as seen below in the list.
Old Mar 15, 2023 | 08:37 AM
ESwift's Avatar
ESwift
CNCFAB
My e99 has no slingers
my 2000 has no slingers
another 2000 I had did have them
I just did seals on an 03 that had them as well
all are 10.5 axles
seems hit or miss, I do not think they are much of a needed item
Old Mar 15, 2023 | 08:39 AM
ESwift's Avatar
ESwift
CNCFAB
Originally Posted by Sous
FYI...
it appears the manual is back and forth as to if they are used as well?
I have never really gone through the manuals before so I was uncertain lol
Old Mar 15, 2023 | 08:53 AM
Sous's Avatar
Sous
FTE Emeritus
The manual has been wrong on several occasions, usually that is in the wiring diagrams with the circuit ID or color code though. I would not put it paste this section to be wrong again, but like Brandonpdx my mind was recalling an oil slinger from somewhere and I could not remember if that was from a video, the manual or my rebuild/maintenance sessions.
Old Mar 15, 2023 | 09:30 AM
mauser3's Avatar
mauser3
4wd Low
The new timken seal 370247a that i have looks like this
Im going to assume that this seal fits more years than my 99 (with or without slinger)
The workshop manual is a bit confusing. How do i know if i have ford or dana axle
Old Mar 15, 2023 | 09:36 AM
Walleye Hunter
The one in the back is a Ford, the one up front is a Dana until you get into the duallies with D80s (I think)..
Patrick4451
2023+ Super Duty
Nov 12, 2022 09:06 PM
irhunter
Jun 21, 2022 12:23 PM
blaczero
May 19, 2021 05:46 AM
jeffkal
Jan 23, 2019 08:28 PM
GregN
Aug 22, 2010 09:52 AM
