What engine do you have? If you have a gas engine, I wouldn't bother at all. I'd give it some thought if you have the diesel.
Every engine has a CCV, crank case vent, that route from the top of the engine and into the intake line. You will get some oil vapor in the air that escapes the vent and that just gets mixed with the fresh air and runs through the engine. On a naturally aspirated gas engine, it's very minimal. On a turbo charged engine, you have more pressure in the cylinders, which leads to more blowing by the rings which can lead to higher pressures in your crank case, meaning you get actual oil coming out that vent and coating the intake side of the engine. A catch can is just a filter that separates the oil from the air so it's only dumping air into the intake and holding on to the oil. It's a matter of preference as to whether you add one or not. Stock, the 6.7 has an air/oil separator, it just doesn't work very well but, there are lots of them on the road having 0 issues without the additional catch can. I added one because I didn't want to keep feeding oil through the intake.
I was just watching a video of somone ripping a 2020 superduty engine apart (with 14k on it) and mentioning he should put a catch can on it due to the amount of oil on top of the heads.
Had never heard of it before but it seemed like an idea.
As long as they’re installed correctly and allow the crank case to vent, they’re never a bad idea, in my opinion. That said, I also don’t know if there’s really a need for one on a non-modified, naturally aspirated gas engine. I had one on an older F150 with the 5.0 because I watched a video showing something similar but I don’t think it really did much. It caught some water vapors but very little oil, nothing that wouldn’t have just passed right through the intake without issue.
I saw that video and was a little surprised too at the oil in the intake. Not sure if it is a long term problem or not, I think they planned to put a whipple on that 7.3 so that may be why they mentioned it.
I will note this about that particular video, by their own admission, they bought that vehicle to mod and tune. I would be willing to bet that thing is run hard a dyno run or 1/8, 1/4 or 1/2 mile at a time. On my Coyote, I added a catch can for the same reason as the guy in the video, it was a tuned truck and the videos I was watching showed that the cam chain was right in front of the PCV valve so it would sling oil off the chain and the PCV would suck it up and throw it through the intake. I really didn't end up running that vehicle hard enough to have the issue, it was more of a precaution. I would wonder if the amount of oil those guys are seeing in that head is a direct correlation to how the truck is being run and tuned.
