Glass Fuse Question
Old Mar 13, 2023 | 02:36 PM
Msaluta's Avatar
Msaluta
Glass Fuse Question
So my turn signal fuse went out. The box calls for a 5x20mm, 15a/32v so I head to AAP and none, head to Autozone and none, head to Amazon and mostly none...with the exception of resellers selling what appear to be old stock...really old stock.
There's plenty of 15a/250 volt in 5x20mm, but from what I know (not much), that voltage doesn't work.
Are these fuses really unicorns? Are there any modern workarounds for a lack of fuse supply?
Old Mar 13, 2023 | 02:44 PM
tbear853's Avatar
tbear853
I kept a bunch. Even a 50 year old unused fuse is as good as new. Old stock is fine, but my Advance store still sells them new.
Volts don't blow fuses ... it is Amps that blow fuses. Amps represent a quantity ... volts represent a quality. I can start an arc with just 12 volts, I can maintain it and weld steel with 90 amps using my favorite rod.
Those 5x20mm15A@250V fuses will work perfectly. They are rated to prevent voltages of up to 250 from leaking by arcs, etc.
Old Mar 13, 2023 | 03:35 PM
mark a.'s Avatar
mark a.
I would stick some tin foil or something in it's holder and see if anything is wrong before risking a good fuse.
Old Mar 13, 2023 | 05:06 PM
Mark8man's Avatar
Mark8man
Yes voltage spec doesn't matter on these as long as the rating is equal to or greater than the application.
garfieldba
Sep 16, 2022 11:19 AM
old28
16
Apr 13, 2019 12:15 PM
abe
19
Oct 31, 2017 09:56 PM
hhight
Electrical Systems/Wiring
Aug 29, 2014 09:00 AM
7278ford
Jul 12, 2009 08:34 AM
