Fuse help
Old Jul 11, 2009 | 03:43 PM
7278ford's Avatar
7278ford
Fuse help
I am having trouble finding 2 fuses for my 72' F100. The previous owner had put homemade "foil" fuse in and now I am finding out why. I can't find a fuse to fit the 20A fuse for the stop and emergency circuit. I am also having a hard time finding the 15A fuse for the circuit right next to it to the left. It is the same length as the 14A fuse for the turn signal and back up circuit. After spending almost an hour in the parts store and then I am lost. Any help would be great.
Old Jul 11, 2009 | 03:47 PM
Madathlon's Avatar
Madathlon
Try a Marine parts store, Many Boats still use Glass type fuses. Just have the leanth and rate and they should be able to match you up
Old Jul 11, 2009 | 06:56 PM
MotorDog's Avatar
MotorDog
Fuses.............
Any NAPA store has all the glass fuses you could possibly need or want! Go the closest NAPA store and you will be good to go!
Old Jul 11, 2009 | 09:20 PM
7278ford's Avatar
7278ford
Well sounds as though I have a few more options then. I will see what I can find.
Old Jul 12, 2009 | 06:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The following typed in BLUE are industry numbers, used by ALL autoparts stores.
The numbers typed in RED are Ford part numbers.
1964/72 F Series Truck 15 & 20 AMP glass fuse types:
AGC15 = 1.25" long / A2AZ14526A
AGW15 = .88" long / C4SZ14526B
AGC20 = 1.25" long / AOAZ14526A
AGX20 = 1.00" long / C5AZ14526B
If you cannot find them in an autoparts store, try a Ford Dealer.
Even tho not used for 20 + years, dealers rarely throw stuff away, and prolly have dozens of each.
These originally came in a package of 5, and dealers used to buy between 5 and 10 packages each.
btw: If you had a 1973 or later, I could tell you exactly which ones you need. But...what I typed above is the only way fuses are listed in the truck parts catalog prior to 1973.
Old Jul 12, 2009 | 08:34 AM
7278ford's Avatar
7278ford
Funny you mention 73' or later. I have a fuse block out of a 79' that I was going to swap into my 72'. From what I can see the wiring is pretty close between the two. The 79' look as though it takes the shared circuits of the 72' and seperates them to their own fuses. Plus, most of the fuses look to be of the same size so there would be no more guessing what size fuse.
Rusty_S
Electrical Systems/Wiring
Feb 20, 2014 08:36 PM
gnwalker
Jan 28, 2014 11:49 AM
Gundown64
2004 - 2008 F150
Sep 23, 2012 07:47 PM
Dr2006
Jun 11, 2009 11:47 PM
Sycostang67
Jun 26, 2007 09:51 AM
