Vibration absorber/timing marks
Old Nov 15, 2003 | 10:52 PM
Tedster9's Avatar
Tedster9
Always just "power timed" my rig w/ 292 V8 (1964) with no problem, if I remember right the vibration absorber might have slipped (laterally and a bit of wobble) and horked the index marks? Does that sound right?
Trying to clean that up before a road trip, runs great at 50 -65 ish but around 80 to 90 mph start getting some belt slippage I think,(Screeeeeeeeeeechh) but I want to get the vibration absorber dead on, it's drilled of course for weight and saving wear and tear on the crank and other parts. No, I don't normally drive at 90 mph but it bugs me. Drives like a cadillac other than that. Poking around town it won't hurt anything, but at highway speeds...
I'm thinking if I can true it out and then JB-weld the outer, vibration part to the inner part. I need to zero it to the timing marks though, or am I just better off biting the bullet and replacing it?
Old Nov 16, 2003 | 07:11 PM
57_ford's Avatar
57_ford
That has happened to mine as well. It even walked it's way back and started to rub the front motor mount. They are hard to find I had to get one off an old engine that was laying the woods. You can have them rebuilt.
Old Nov 17, 2003 | 12:58 PM
286merc's Avatar
286merc
That is a common problem when the rubber seperates allowing the two sections to rotate independently.
Rebuilds are around $100 so you might want to check around first.
Old Nov 17, 2003 | 01:10 PM
Tedster9's Avatar
Tedster9
Hm, anyone got a part # for that? I might have an extra but I doubt it. Getting hard to find? Removal should be no problem w/ a puller but I hate getting into stuff like that with hard-to-find parts.
Old Nov 17, 2003 | 09:10 PM
red56flatty's Avatar
red56flatty
I know your problem. I too had the damper ring come off the pulley and work its way back until it began rubbing on the front motor mount. I found a company in New York called Job Lot Automotive Inc. They sell the pully/dampers for about $70, granted it was made in Venezuela. This company had a lot of NOS stuff for my '56 F350. The web address is www.joblotauto.com.
After I put my new damper assembly on, I scribed two lines on the crank pulley that match up at TDC and 10 degree advanced so I can tell quickly in the future if the damper is beginning to slip. Hopefully this helps. Good Luck!
90turbo1
Sep 13, 2014 12:03 AM
raycgl
Aug 17, 2014 10:17 PM
stephen.osborne1
2009 - 2014 F150
15
Dec 21, 2013 04:19 PM
Pioneer Ford
1978 - 1996 Big Bronco
35
Dec 27, 2002 09:13 AM
Cardude_mad
Aerostar
Apr 24, 2002 07:33 PM
