5r110w
Old Jan 28, 2023 | 12:24 AM
jake1928's Avatar
jake1928
5r110w
Does anybody know what would cause a transmission that hasn’t had any problems and never over heats all of a sudden quits going into gear and when I got the pan pulled off there was a lot of metal in it and the fluid was actually a metallic black????
Old Jan 28, 2023 | 01:13 AM
Hartwig's Avatar
Hartwig
When was last service done (fluid, both filters)?
Old Jan 28, 2023 | 05:44 AM
bismic's Avatar
bismic
https://www.ford-trucks.com/forums/1...-problems.html
Maybe if you hit something on the interstate ...................
Was the pan damaged (previous thread question)?
Why two threads on it, you had some good help going on in that thread?
Another possibility, in addition to the maintenance practices (yours and any previous owner), is running a tuner and towing big loads.
Old Jan 28, 2023 | 09:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I know! Something broke inside the trans. Pull it out, tear it down, and then you will have your answer. Anything else is just guessing.
Old Jan 28, 2023 | 12:21 PM
jake1928's Avatar
jake1928
No the pan wasn’t damaged. I thought I had to start a new thread cause I was asking a different question.
Old Jan 28, 2023 | 12:46 PM
bismic's Avatar
bismic
One thread is fine.
I am serious about the tune and the tow.
15,000 lb trailer is a big load. What tune are you running on that SCTX4?
Old Jan 28, 2023 | 01:07 PM
jake1928's Avatar
jake1928
One thread is fine.
I was running an extreme tow from total diesel performance. I got a h&s mini maxx for Christmas the 109003 one and I have it installed currently. I towed once with the new one about a week ago. I pulled a Nissan Altima on a big u-haul car hauler trailer from paintsville Kentucky back to candler North Carolina.
Old Jan 28, 2023 | 01:52 PM
Byrd.Dog's Avatar
Byrd.Dog
If you still have the tuner installed, try returning it to stock tuning. That will provide a good baseline for any troubleshooting.
Old Jan 28, 2023 | 05:29 PM
jake1928's Avatar
jake1928
I uninstalled it when the transmission started acting up
Old Jan 28, 2023 | 09:54 PM
IHateCommieCars's Avatar
IHateCommieCars
Have you tried pulling codes? IDK, and trust Mark K's advice on trannies. Metal not good. Does the fluid smell burnt? I've had to replace the wiring harnesses on mine when it quit shifting right, but there were codes indicating that.
Old Jan 28, 2023 | 11:00 PM
bismic's Avatar
bismic
IMO it was too late.
Old Jan 29, 2023 | 10:08 AM
Mark Kovalsky
The damage had already been done. It's like unloading the gun after it's shot someone.
Old Jan 29, 2023 | 03:07 PM
IHateCommieCars
Mark gets all the easy questions. Has Hartwig ever rebuilt one of these? I'm just another cheapazz know-nothing; harnesses, solenoids and fluids are about as far as I go with these transmissions. Mark needs a challenge.
Old Jan 29, 2023 | 03:35 PM
Hartwig's Avatar
Hartwig
The way I read this, in addition to the transmission overhaul, the radiators need to be replaced and the lines meticulously cleaned.
Old Jan 30, 2023 | 11:50 PM
jake1928's Avatar
jake1928
Does anyone know if it’s possible to remove the transmission without lifting the truck?
