5r110w
Old Jan 30, 2023 | 11:54 PM
jake1928's Avatar
jake1928
Originally Posted by Mark Kovalsky
I know! Something broke inside the trans. Pull it out, tear it down, and then you will have your answer. Anything else is just guessing.
You were right something did break. I think a lot of stuff broke in it. I finally had a chance to get under it today and there was transmission fluid all up under there. I found somebody that said they would rebuild it and upgrade it if I brought the transmission to him for 3000. Does that seam like a fair price? Is it possible to remove the transmission without lifting the truck?
Old Jan 31, 2023 | 04:32 AM
Mcrafty1's Avatar
Mcrafty1
It may be possible...depending on how high the ground clearance is under your truck......but it isn't going to be nearly as much fun as if it was lifted high enough to stand under it.
Old Jan 31, 2023 | 06:17 AM
jake1928's Avatar
jake1928
what’s gonna be even more fun is that my driveway is a hill. I’m not looking forward to this. When should I flush it? Right before I remove it? How do I flush it? Never done a flush before.
Old Jan 31, 2023 | 06:31 AM
Mcrafty1's Avatar
Mcrafty1
what’s gonna be even more fun is that my driveway is a hill. I’m not looking forward to this. When should I flush it? Right before I remove it? How do I flush it? Never done a flush .
Ive never done a flush myself but I'm sure there are many one here that have, someone will chime in, I'm sure. Good luck with the project.
Old Jan 31, 2023 | 09:06 AM
bismic's Avatar
bismic
I assume you intend to continue towing that 15k lb, 40+ ft, trailer. If so, you might consider what upgrades would be needed to do that reliably.
Also, I wouldn't consider either of your tunes / tuners safe going forward, but there are people here that are WAY more knowledgeable on that than I am.
I would recommend doing some searches and maybe even start a new thread about upgrades that would make sense.
@JJ1101
@utahtom
@mrgrayaz
@jetjockey99
A few others I can't recall at the moment
https://www.ford-trucks.com/forums/1...our-6-0-a.html
Old Jan 31, 2023 | 09:47 AM
jake1928's Avatar
jake1928
[QUOTE=bismic;20725782]I assume you intend to continue towing that 15k lb, 40+ ft, trailer. If so, you might consider what upgrades would be needed to do that reliably.
@JJ1101
@utahtom
@mrgrayaz
@jetjockey99
https://www.ford-trucks.com/forums/1...our-6-0-a.html[/thanks I’ll do that nowQUOTE]
Old Jan 31, 2023 | 12:57 PM
Fuzzpuss's Avatar
Fuzzpuss
Does anyone know if it’s possible to remove the transmission without lifting the truck?
I've seen a few members speak highly of Harbor Freight's big transmission jack. Pretty sure this is the one:
https://www.harborfreight.com/800-lb...ack-60234.html
namnguye
Jun 7, 2021 10:46 AM
Money-Pit
Nov 17, 2013 05:45 PM
victorminisan
Jan 26, 2010 01:10 AM
snotwilim
Oct 10, 2005 12:12 PM
MustangGT221
Oct 28, 2002 12:30 PM
