DROPED THE PAN ON E40D
Old Oct 23, 2002 | 05:25 PM
MustangGT221's Avatar
MustangGT221
Old Oct 28, 2002 | 12:30 PM
tsheriff's Avatar
tsheriff
I DROPED THE PAN ON MY TRANNY SAT TO CHANGE THE FLUID AND FOUND ALOT OF CRAP STUCK TO THE MAGNET. THE MAGNET IS ABOUT 1.5" DIA. WHEN I FIRST DROPED THE PAN IT LOOKED LIKE A SMALL SNACK DONUT IN THE PAN. THE CONSISTENCY OF THE MATERIAL WAS OF GRITTY GRAPHITE. TOOK FOREVER TO GET THE STUFF OFF. i COULD NOT GET THE BOLTS OFF THE PLATE TO GET TO THE CONVERTER DRAIN SO I LEFT IT ALONE. THE FLUID WASNT THAT BAD, SEEN WORSE BEFORE. WAS ALL THIS STUFF THE BAND MATERIAL OR SOMETHING ELSE. AFTER FILLING IT UP I LET IT RUN TO CHECK THE FLUID. I WAS UNDER THE TRUCK LOOKING FOR LEAKS AND IT SOUNDED LIKE SOMEONE WAS TRYING TO GET OUT OF THE TRANY. LIKE A NUT ROLLING AROUND IN A COFFEE CAN. DON'T KNOW IF ITS STILL DOING IT WILL CHECK WHEN I GET HOME. UP INSIDE BEHIND THE VALVE BODY WAS KINDOF A DRUM LOOKING THING INLINE WITH THE OUTPUT. FROM THE AMOUNT OF IT I COULD SEE HALF LOOKED BROWN AND THE OTHE LOOKED BLUE. lIKE BURNT METAL LOOKS. WHAT WAS IT.
EITHER WAY ITS GETTING CHANGED SOON.
